M-Class Memphis Subwoofers
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=28470
Printed Date: April 05, 2026 at 3:58 PM
Topic: M-Class Memphis Subwoofers
Posted By: DaLynQwenT
Subject: M-Class Memphis Subwoofers
Date Posted: March 16, 2004 at 10:35 AM
Hey, I'm thinking about getting a pair of these 12" inch subwoofers, anybody have a pair, and care to comment on them??
I've heard they're awesome subs, I just want to hear anyones pros/cons about them. Thanks.
Posted By: ksin291
Date Posted: March 16, 2004 at 3:27 PM
By M-class I am assuming that you are referring to the new M3 subs from Memphis, these subs have replaced the HPO line but are technically the same. I have owned Memphis Car Audio gear and must say that they make quality stuff. I had a pair of Memphis HPO's being pushed buy a Memphis ST-1000D in a sealed enclosure and they thumped, they had good SQ too. So in short they are great subs but you should see if you can find them locally and give that a listen yourself as you will be the ones listening to them everyday.
Posted By: netboy
Date Posted: March 23, 2004 at 4:31 PM
M-class subs are the ones below the M3.  Still a great sub, but has a smaller magnet and can't handle as much power as the M3.  Aslo the m3 has an interchangable basket.  So if you buy a 12" m3 and later you want to upgrade to a 15" all you do is unscrew the magnet and go see your local memphis dealer.  Works great also when you blow subs.
Memphis MC-1300
2 12" JLw6v2
Diamond audio M3 6x9
Diamond audio M3 5.25 components
Audio control Matrix
Carputer
