MTX Thunderform
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=28521
Printed Date: April 04, 2026 at 4:17 AM
Topic: MTX Thunderform
Posted By: bcuz
Subject: MTX Thunderform
Date Posted: March 16, 2004 at 9:00 PM
I want to put a sub in my 98 GMC Sierra Ext Cab.  Is the MTX Thunderform worth the cost?  Where can I get plans to make an enclosure for one 10" or 12" sub that will not require the jack to be removed from under the rear seat?  As usual, thanks for your help.
bcuz
Posted By: superstreet786
Date Posted: March 16, 2004 at 9:57 PM
Thunderforms are really good... they sound awesome
---- 1996 Chevy S10 ----
1 Lightning Audio S2.600.2 Amp
2 Lightning Audio 12" Subs
1 Lightning Audio 1 Farad Cap
Posted By: fuseblower
Date Posted: March 17, 2004 at 7:39 AM
They sound good but can sometimes flex causing you to loose out on some bass.  Also, be sure that your amp will not over power the subs because the dual sub truck boxes are wired to run mono.
