Wiring Subs question
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=28670
Printed Date: May 16, 2026 at 9:07 AM
Topic: Wiring Subs question
Posted By: bradsyukno
Subject: Wiring Subs question
Date Posted: March 19, 2004 at 2:32 PM
I have 2-12" Audiopipe TS-PR12YW 4ohm dual voice coil subs.  I want to hook them up to a Punch 601s amp and bridge them.  What is the suggested way to wire these together to get the most out of them or for them to perform better.  I was looking at some wiring diagrams on Rockford's website and did not know exactly which one was what I needed.
Mr Hexed
Posted By: thapimpfromchi
Date Posted: March 19, 2004 at 3:00 PM
wire the each sub in parallel, positive to positive, and negative to negative, then run the subs in a series, to get a 4 ohm load, to bridge the amp.
1990 Honda Civic HB:
Clarion DXZ545MP H.U.
2- 6.5" Power Acoustik interiors
Diamond Audio 600.1 amp
Diamond Audio 15" M6MKII
Pyramid PB881X 4 CH. Amp
Date Posted: March 19, 2004 at 3:06 PM
This is a diagram I found.  This is how you are saying to wire these.  All the + together, ran to the+ on one channel.  All the - together, ran to the - on the other channel.  Right?
Example:
Mr Hexed
Posted By: forbidden
Date Posted: March 19, 2004 at 3:08 PM
Here is how I would wire them.
Wiring Option #2
posted_image
Date Posted: March 19, 2004 at 3:16 PM
#2 Diagram:
Out the two diagrams I posted, which would be better or correct?   Dia #1    or     Dia #2
I thought this would be another way to wire them.  4 ohm speakers =4ohm load
posted_image
Mr Hexed
Date Posted: March 19, 2004 at 3:27 PM
Your way happens to be identical to how I would wire them, how about that!
Date Posted: March 19, 2004 at 3:30 PM
yea, well, to me, what forbidden says goes. There are 2 ways to do it, and get a 4 ohm load, but thats probably the safer way. Enjoy.
Date Posted: March 19, 2004 at 3:39 PM
I will wire them with the way forbidden suggested.
The Punch 601s  is 600 W X 1 @ 4 Ohms Bridged RMS.  My subs are rated at 750 Watts Power (PMPO), 375 Watts Power (RMS).  If that rating were exact on the watts, would that mean I would be pushing 300 watts to each sub or would it be 600 watts to each.  How is the wattage divided up to the subs?
Mr Hexed
Date Posted: March 19, 2004 at 5:35 PM
The total wattage is divided equally among the subs first and equally among the voice coils, thus each sub gets 300 watts and each coil gets 150 watts.
