Speakerbox Question
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=28777
Printed Date: May 15, 2026 at 7:10 AM
Topic: Speakerbox Question
Posted By: jbjohn22jb
Subject: Speakerbox Question
Date Posted: March 21, 2004 at 12:44 PM
I am sure this has been covered. According to Audiobahn.com, for my subs, I need a 1-2 cu ft box for the type of subs I have. Does anyone know if that is per sub or if that is for the pair? I am going to build a new box today and I am a little perplexed about the airspace needed. Thanks for the help. _____________________________ 91 Honda CRX DX, Kenwood Head Unit, Audiobahn A275 HCT Amp, 2 Audiobahn AWI25IT Subs, Legacy 3 Fd Cap, Tsunami 1 Fd Cap
Posted By: superstreet786
Date Posted: March 21, 2004 at 1:30 PM
Im almost positive thats just for one... the usually will never give it to you for 2 and 1-2 in quite small for 2 subs.
------------- ---- 1996 Chevy S10 ----
1 Lightning Audio S2.600.2 Amp
2 Lightning Audio 12" Subs
1 Lightning Audio 1 Farad Cap
Date Posted: March 21, 2004 at 1:56 PM
Thanks superstreet, Thats what i thought as well but I didn't want to build something that was too small.
Posted By: DYohn
Date Posted: March 21, 2004 at 2:13 PM
Specifications and suggested enclosure size are always given for one woofer. If you want to use two, you're best bet is a seperate enclosure that meets the specs for each one.
Date Posted: March 21, 2004 at 2:33 PM
Hey Dy, Does that mean that I can build one box and then put a seperator inbetween tha subs to kinda form to chambers? Even though this will be a sealed enclosure, Would it be wise to have two seperate chambers? Each equal to the manufacturers specs. Pros? Cons?
Posted By: DYohn
Date Posted: March 21, 2004 at 3:54 PM
Yes, this is the only way to do it PROPERLY. You can build one enclosure with two chambers, or two seperate enclosures. Sealed will sound better and allow higher power input than ported. Ported is louder. In general, that is. :)
Date Posted: March 22, 2004 at 8:47 PM
Thanks again DY, Construction is under way. I just need to put the ends on and cut holes for subs and connections. Each sub will have almost 2 cu ft in the sealed, two chamber box.
------------- "I'm only doin' this for ya because I heard that Buffalo Bob guy shoved a road flare up yer bunghole...."
Kenwwod 315s
2 Audiobahn AWI25IT
1 Audiobahn A275HCT
1 Tsunami 1.0
1 Legacy 3.0
