would this work
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=28798
Printed Date: May 15, 2026 at 12:08 AM
Topic: would this work
Posted By: southside
Subject: would this work
Date Posted: March 21, 2004 at 6:05 PM
  • Built with 3/4" MDF.
  • 1.25 cubic feet per side
  • Divided chambers
  • Dimensions: 43.5" Width x 20" Depth x 14" Height
  • Four high quality terminals
  • Four 12" speaker holes - fine cut
  • Sealed with several different sealers to ensure quality and make sure air does not leak.
       mounting diamiter 11" (284 mm)
    posted_image
    posted_image
    6" (153.4 mm)
    this is for cerwinvega 12in v-max. 4ohms independance dvc subs i'm getting four of them. an this is for a 4 sub box. 300w rms, 800w peak. let em kno thanks.
    southsider
    Posted By: DYohn
    Date Posted: March 21, 2004 at 6:46 PM
    You're putting 4 subs into 2 chambers, or 4 subs into 4 chambers?
    Date Posted: March 21, 2004 at 6:47 PM
    the box is a 4 chamber box. so yes i'm putting 4 subs in there.
    southsider
    Posted By: DYohn
    Date Posted: March 21, 2004 at 6:49 PM
    Good plan.  Give them enough power and it should lift your car's wheels off the ground with the sonic recoil.  :)
    Date Posted: March 21, 2004 at 6:51 PM
    ya forbidden told me to get that 1501 bdrockford so it's a good thing that each sub has there own chamber?
    southsider
    Posted By: DYohn
    Date Posted: March 21, 2004 at 6:55 PM
    Yes, it is the BEST plan.  The BD1501 is a great amp if you can find one.
    Date Posted: March 21, 2004 at 7:03 PM
    thank u very much
    southsider
