kicker l7 question
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=28988
Printed Date: May 15, 2026 at 7:06 AM
Topic: kicker l7 question
Posted By: Kid777
Subject: kicker l7 question
Date Posted: March 24, 2004 at 10:36 PM
Currently I have a kicker 12" l5 in a sealed box with 400w rms going to it. This setup sucks and the sub is the DVC 2ohm version wired for a 4ohm load.  I bought this used and didn't understand the DVC thing etc. I now know i want the 4ohm DVC so i can get a 2ohm load.This is in an expedition
Now heres my question-I'm getting rid of the amp i have regardless. Do i get a 12" l7 4ohm DVC put it in the sealed box i already have wired for a 2ohm load and run about 700w rms to it or should i go bigger and get a 15" l7 new box and run 1000w rms to it
Basically i want something that will shake my truck good. It would be nice if i could still use the kicker sealed box i have but if the 15 will be that much better i'll make it happen
thx
E
Posted By: Ravendarat
Date Posted: March 25, 2004 at 8:05 AM
Why not just keep your 12" L7 that you have and buy an amp that is stable to one ohm. Then you can wire it in parrell and save the cost of getting another sub. Just a thought
Posted By: 94bonny
Date Posted: March 25, 2004 at 10:07 AM
because he has a L5 correct? if your upgrading your amp you might as well upgrade your sub to the square L7 15" if your intentions are to create some serious shake in your rear.  but if you dont wanna cough up the dough for a 1000 watt amp and would rather go for the 750, the L7 12" would do you justice, but if you do go for the L7 15" i would recomend porting your box as this will make your woofer sound a great deal louder.
Alpine cda 9813
jl 500/1
eclipse aluminum 15"
Posted By: Kid777
Date Posted: March 25, 2004 at 10:56 AM
yea its an l5
Posted By: flatulatta
Date Posted: March 25, 2004 at 12:34 PM
if you can spare it why not go with 2 L7 10s instead of a 12 it would be faster and louder if im not misaken... someone correct me if im wrong
Date Posted: March 25, 2004 at 12:44 PM
im sorry, apperently I cant read. 2 10's would be louder but would require almost double the power which equals way more $$$$$
Date Posted: March 25, 2004 at 3:02 PM
yes... but he did want to go with a 15 L7 and a 1000w amp... so it would cost almost the same depending on where he gets it from
Posted By: brad123
Date Posted: March 25, 2004 at 3:24 PM
Tell me what kicker stuff you want I have alot of new stuff, the new l7 and amps so let me know and i can get you a price.
Brad
Posted By: thapimpfromchi
Date Posted: March 25, 2004 at 4:41 PM
Hey man, do you want to stick with kicker stuff? i mean, if you're gonna be upgrading, im sure theres some stuff that can pound alot better for cheaper.
1990 Honda Civic HB:
Clarion DXZ545MP H.U.
2- 6.5" Power Acoustik interiors
Diamond Audio 600.1 amp
Diamond Audio 15" M6MKII
Pyramid PB881X 4 CH. Amp
Posted By: forbidden
Date Posted: March 25, 2004 at 4:53 PM
You guys have thoroughly confused the issue, no worries though. The original question and statement the poster made is incorrect. He is assuming that he must have a dual 4 ohm coiled sub to run at 2 ohms to get more power. The two subs in question, be it dual 2 ohm or dual 4 ohm can handle the exact same amount of power. Thus he does not need to change the sub, maybe he just needs a 2 channel amp that produces a maximum of 450watts rms at 4 ohm mono, which his current sub will handle and in fact he lists that he has 400 watts running to it. If he should change the sub to a similar sub with dual 4 ohm coils, then he now needs a mono sub amp that provides 450 watts rms at 2 ohm mono. The exact same thing as what he basically has now. This gets him absolutely nowhere.
If you want to keep the gear that you have, the first thing that you should do is make a big ported box for your sub, this will drastically increase the output of your sub, at the expense of good sound.
Should this not be enough for you in such a large vehicle, then we can look at some alternatives. Open your mind to something other than Kicker and a whole world of opportunities for SPL and SQ will present themselves..
Posted By: Kid777
Date Posted: March 25, 2004 at 5:21 PM
yes i'm open to anything.
please suggest something for my application. I'm looking for the best bang for the buck. 1st priority is SQ then spl.  I'd really like to stick with a sealed box as i listen to all kinds of music also. Any input would be greatly appreciated.  Basically i'm looking for something that will sound good and give you that feeling in your gut when it hits.
thanks
E
Date Posted: March 25, 2004 at 6:02 PM
Do you have a budget? Are you in the Great White North or are you in the land of people everywhere? Is this something that you are going to install yourself or have done for you based on our recommendations?  I'm a little busy at the shop today so it may take me some time to get back to you.
Posted By: Kid777
Date Posted: March 25, 2004 at 7:57 PM
I'm in Indiana
The wires are already run etc from my current setup so i was hoping i could just swap the amp and subs in.
Date Posted: March 26, 2004 at 12:57 AM
what size wires do you have running for the amp? If you have 4 gauge, ur good. less than that, u might wanna consider upgrading to atleast 4 gauge. also, we're gonna need a budget u are willing to work with. The options are endless. there is a perfect set up for you, you just have to give us a little bit to work with.
Date Posted: March 26, 2004 at 1:01 AM
You know what, Forbidden is right. We all have an uncanny knack at confusing the situation on this forum. Whenever some poor guy asks for help installing an amp, or asking why his subs stopped working,we have him buying 3000 in upgraded gear by the time the thread is done. Im as bad as anyone else. We need to try to stick to the topics more so we dont confuse people so often. Just a thought
