ohms?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=29145
Printed Date: May 13, 2026 at 12:51 AM
Topic: ohms?
Posted By: invast
Subject: ohms?
Date Posted: March 27, 2004 at 10:39 PM
I'm just confused about ohms.  Like what is the difference between a 4ohm sub and a dual 4ohm sub.  And is 2ohms better than 4ohms, or.. what is the difference.  If someone could explain this to me I would greatly appreciate it.  Thank You.
Posted By: Clean Install
Date Posted: March 27, 2004 at 10:55 PM
With a 4 ohm dvc you have the option of wiring it in parrell or series...which will create differnt loads that the amp will see....for instance a dual 4 ohm voice coil can either be wired in parrell for a 2 ohm load or in series for a 8 ohm load.....so you have more options with a dvc compared to a singe voice coil....
If we learn from each success and
each failure, then we can improve ourselves
Date Posted: March 27, 2004 at 10:57 PM
is 2 ohm or 4 ohm better?
well that depends on your amp if  your amp is 2 ohm stable....if not then a 2 ohm load would not be best...
Posted By: invast
Date Posted: March 27, 2004 at 11:02 PM
what benefits does 2ohm have over 4ohm?
Posted By: DYohn
Date Posted: March 27, 2004 at 11:05 PM
2 ohms is no better or worse than 4 or 8 or anything else.  It depends on the quality of the speaker and the quality of the amp.  The purpose of knowing the ohm rating of the speaker (and the purpose of being able to wire systems for different ohm loads) is to match the speaker to the proper amplifier.  The only reason to run low ohms is to squeeze more current out of the amp - which makes it louder, noisier and hotter.  Higher ohm loads means the amp will run cooler and with less noise.  It will also last much longer.  The best sounding most high quality system I ever built - an SQ award winning system, by the way - used a set of subs wired to load the amp at 16 ohms.  It all depends on what you are trying to accomplish.
For most people who just want a good sounding system that will last a long time and not fry, run 4 ohm speakers.
Posted By: invast
Date Posted: March 27, 2004 at 11:08 PM
ahhh ic, thank you both very much you cleared alot up for me.
