mustang mach460 stereo system
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=29191
Printed Date: May 12, 2026 at 1:56 PM
Topic: mustang mach460 stereo system
Posted By: mxxmikexx
Subject: mustang mach460 stereo system
Date Posted: March 28, 2004 at 4:09 PM
what do i need to do in order to change the head unit in a mustang with the mach 460 system? can i simply do it with a metra 70-5510 harness? and just feed the low level from the new head unit to the factory ford amp?
Posted By: Teamrf
Date Posted: March 28, 2004 at 5:25 PM
Well you can either by-pass that amp..or you can re-wire the whole car.
------------- ~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Date Posted: March 28, 2004 at 5:34 PM
so you cant feed low level from an aftermarket head unit into the factory amp?
Posted By: chriswallace187
Date Posted: March 28, 2004 at 8:18 PM
The Metra 5510 harness uses the 8-pin rectangular gray plug for the head unit's power supply and RCAs going to a square black plug for the audio output, am I correct?
If that's the case then you should be able to run the low level into the factory amp without any problems.
Posted By: davedyer79
Date Posted: March 29, 2004 at 9:58 AM
If you want to be absolutely sure, do a profile for the member MetraTech. He is tech support for Metra, and probably knows more about harness's than anyone else. Good luck
------------- davedyer79
Posted By: momo stallion
Date Posted: March 29, 2004 at 11:29 AM
i have an 02 mustang gt that HAD the 6 disc. i had bought two metra peices, one i had to order... i tied in like normal then i have another harness that allowed me to use my front and rear preouts. i dont know what they are anymore i have removed the 460 now.
i have an 02 mustang gt that HAD the 6 disc. i had bought two metra peices, one i had to order... i tied in like normal then i have another harness that allowed me to use my front and rear preouts. i dont know what they are anymore i have removed the 460 now. but the install manager at circuit city looked it up and ordered it for me.
