VW Clarion connection problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=29874
Printed Date: May 07, 2026 at 5:10 AM
Topic: VW Clarion connection problem
Posted By: salris
Subject: VW Clarion connection problem
Date Posted: April 07, 2004 at 1:06 AM
I have a Volkswagen Passat 1999 with original Clarion PU1634 (1J0 035 186) radio. I changed the radio to Sony and now I have this original available for other purposes. I had an idea that I want to use it as a carage radio, but the connection is a problem. The radio has the following connections diagram on the case: KL31, KL30, KL58b, S, SAFE, K-LN, ALM and also the speaker diagram I tried to connect the +12V and ground (KL31 and KL30 which have been proven to be correct), but nothing happened. Can anybody give me any ideas which wires I have to connect to get it working and also the explanation about the above connections. Any help would be appreciated. Rise
Posted By: DYohn
Date Posted: April 07, 2004 at 10:38 AM
No idea what the above connection designators mean, but I assume they are VW specific labels and can be found in the vehicle's wiring diagrams. You will need, as a minimum, to conenct +12V, Ground, AND switched power. ------------- Support the12volt.com
Posted By: kgerry
Date Posted: April 07, 2004 at 11:16 AM
you need to power safe as well we sell the connectors to plug right into that radio
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: salris
Date Posted: April 07, 2004 at 12:17 PM
Kevin, I have the CD changer for the radio as well (panasonic 6 disc changer, original with the car). I want to connect the changer into the radio. Do you have that cable available? Regards, Rise
Posted By: Alpine Guy
Date Posted: April 07, 2004 at 9:30 PM
Whats your e-mail, , i can send you a pic of the plug showing the proper wire colours. ------------- 2003 Chevy Avalanche,Eclipse CD7000,Morel Elate 5,Adire Extremis,Alpine PDX-4.150, 15" TC-3000, 2 Alpine PDX-1.1000, 470Amp HO Alt.
Posted By: salris
Date Posted: April 07, 2004 at 11:57 PM
Jason, I have updated my profile and you can find my e-mail address from there. ------------- Regards
Rise
