03 Ford Factory Blaupunkt Radio
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=29897
Printed Date: May 07, 2026 at 8:18 PM
Topic: 03 Ford Factory Blaupunkt Radio
Posted By: lavaweb
Subject: 03 Ford Factory Blaupunkt Radio
Date Posted: April 07, 2004 at 2:04 PM
Hey all, i'm replacing my factory MP3 radio with an Aiwa 9827, now when i pulled the factory deck out, it had three plugs, a grey, black and multi colored one. The wiring harness i was sold olnly have places for the black and grey plugs though.
i'm wondering, what the multi-colored plugs are, and what is hould do with them. thanks
Also, just so you all know, the installation person at the audio place i go to did a quick test and noticed that my cars red and yellow wires are reversed, does anyone else have this issue?
Posted By: lavaweb
Date Posted: April 08, 2004 at 10:20 AM
Anyone have any ideas? I'd love to know before I try to get this new radio in.
Posted By: Sweekster
Date Posted: April 08, 2004 at 10:52 AM
I think there may be an amp in your car. That's prorbably what the third plug is for. Which ford is it? A Focus? What you may have to do is obtain the wiring schematic for your car from the dealership. Since you have the standard plug adapter...hook up the radio and see what happens. If you get no sound when you plug it up...then there's an amp in the some where.
Duane...
If you think you're confused, imagine how you feel.   posted_image
Posted By: lavaweb
Date Posted: April 08, 2004 at 10:59 AM
ok great i'll try it out and post the results, thanks for your help.
Posted By: bfog99
Date Posted: April 08, 2004 at 1:04 PM
i have an 03 focus. when i replaced the factory deck i only used the back and gray. the multicolored one i think is for the special features of the radio, like how you can turn it on with the car off. but you should be fine with just the black and gray
Date Posted: April 08, 2004 at 1:32 PM
I just double checked the wiring on my sister in laws 2001 focus.    I installed a kenwood in her car last year. Bfrog is right. The other plug is not used. Just use the black and the gray plugs and it should work.
Duane...
