Tweeter install help
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=30010
Printed Date: May 09, 2026 at 11:17 AM
Topic: Tweeter install help
Posted By: metalgear
Subject: Tweeter install help
Date Posted: April 08, 2004 at 7:22 PM
Just bought a pair of tweeters and I am planning on hooking them up using the door speakers as well ( just low range ) while putting the tweeters on the dash for a little better sound. They are cap filtered with +- in and +- out of little filter box. How would I go about wiring these tweeters up? Should I just wire them parralel with the existing speakers? (ex. cutting wire to other speaker and making a 3 way splice in the dash. )
Posted By: customsuburb
Date Posted: April 08, 2004 at 7:47 PM
Wiring them in parallel should be fine. Are you sure you want to put them on your dash? You might want to try putting a long wire on them and listen to them mounted on different locations up front (like around your door panel and different places on your dash).
Date Posted: April 08, 2004 at 7:59 PM
Yeah, My basic idea was to use the angled mounts they came with, and try a few different places first. Most likely will put them on either far side of the dash ( back toward the windshield ).
Date Posted: April 08, 2004 at 8:48 PM
I spliced the wires behind the deck and connected one of the tweeters a few minutes ago, It cuts off the low on the other speaker.. /shrug/ so in essence i only have the one tweeter instead of a tweeter and a low.
Date Posted: April 08, 2004 at 9:34 PM
hmm.. are all your connections secure? It might be too low of impedance for your head-unit to handle. Is it an aftermarket or stock one?
Date Posted: April 09, 2004 at 11:27 AM
Head unit is a pioneer 8400
speakers are run of the mill pioneer 2 way 200 watts
tweeters are power acoustik NEO-30x
All connections are secure.
Date Posted: April 09, 2004 at 11:28 AM
my cars wiring map says that both front speakers have a common (-) wire off the deck, Does this sound right ?
