Chevy tahoe rear speakers
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=30380
Printed Date: May 15, 2026 at 4:25 PM
Topic: Chevy tahoe rear speakers
Posted By: chevyman26
Subject: Chevy tahoe rear speakers
Date Posted: April 14, 2004 at 7:58 PM
I put a Alpine headunit in my 99 tahoe with a scosche harness, now speakers in rear door don' t work but the 4x10 's in the rear ceiling do. Anyone know how to tie these speakers together (series or parallel)? Or any other tips or tricks? Thanks
Posted By: customsuburb
Date Posted: April 14, 2004 at 8:03 PM
Wire the roof 4x10s and door speakers in series:
posted_image
Posted By: sparkie
Date Posted: April 14, 2004 at 9:14 PM
There is a pink wire in the truck's radio harness that needs to be hooked up to the radio's remote wire. This will turn on the small amp under the driver's side dash that powers the rear door speakers.
sparky
Date Posted: April 14, 2004 at 9:33 PM
I'm pretty sure there isn't an external amp in the 95 to 99 model of suburban.
Date Posted: April 15, 2004 at 7:26 AM
The only wires on the vehicle harness that aren't matched up to wires on the radio harness are a dark GREEN/ black (VSS for factory speed comp. volume) and two wires that resemble speaker wires (I think they are light green and light GREEN/ black. My wife has it at work right now so I can't check, but I know they didn't match any of the wires for the other 4 speakers.) It seems as if one would be pos. & one neg., but would there be only one set for 2 speakers?
You'd better get me out of this lord... or else you'll have me to deal with. -- Hunter S. Thompson "F.A.L.I.L.V."
Posted By: sparkie
Date Posted: April 15, 2004 at 8:00 PM
There should be an amp for the two rear door speakers under the driver's side dash right of the brake pedal. If there are speakers in the doors ( check behind the door panel grills) then they are run only by this amp. The radio triggers a relay next to the amp. The trigger wire is pink and activates the orange power feed to the amp. The amp doesn't even look like an audio amp. It is a small silver box usually. Have a look under the dash. The correct plug will have all 4 of the rear speakers going into it plus an orange and a black wire. I think the output wires to the speakers are tan white and red.
sparky
Date Posted: April 15, 2004 at 9:14 PM
FYI: I know what is in a chevy suburban and there is no such amp on this year of the suburban.
Date Posted: April 16, 2004 at 7:25 AM
Hey man! Sparky's right! Just as you described. Works great now. Thanks!
