Capacitor & Circuit Breaker
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=30387
Printed Date: May 15, 2026 at 5:57 PM
Topic: Capacitor & Circuit Breaker
Posted By: Jay T
Subject: Capacitor & Circuit Breaker
Date Posted: April 14, 2004 at 8:52 PM
If I have a breaker installed before a Cap does it matter if I shut off the breaker?  Will the cap do some funny stuff or discharge?  Someone tell me if this is important or not.
Thanks!
Posted By: Ketel22
Date Posted: April 14, 2004 at 11:26 PM
if you shut off the circuit breaker, nothing out of the ordinary should happen, if something does you have serious problems with your install.
Quad L Handyman services
Posted By: speedwayaudio1
Date Posted: April 14, 2004 at 11:44 PM
the cap will still be charged, and can short to ground. It can also knock the crap out of you so be careful.
Big Dave
Posted By: Ketel22
Date Posted: April 15, 2004 at 12:05 AM
yes it is definately a "shock" to have a cap discharge on you.
Posted By: Jay T
Date Posted: April 15, 2004 at 1:46 PM
So If i shut kill the power with the circuit breaker when I go in at night and go in and flip it on in the morning, no harm done to Cap?
Also with car running LED voltmeter is on. but when I shut the car off and just use accessory power the voltmeter goes off like the cap isn't working.  How does this affect it?  Will it just discharge as I listen to my stereo?  And if so isn't it bad to fire it up and get a quick charge all at once, or does it not matter because its already connected.
Thanks dudes!
Posted By: Teamrf
Date Posted: April 15, 2004 at 3:43 PM
I to this day won't use a circuit breaker..I will always use a in-line fuse.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
