does anyone own a Pioneer GMX424 Amp?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=30402
Printed Date: May 16, 2026 at 1:32 AM
Topic: does anyone own a Pioneer GMX424 Amp?
Posted By: jjl2191
Subject: does anyone own a Pioneer GMX424 Amp?
Date Posted: April 15, 2004 at 2:54 AM
i've got a problem with this amp. the power indicator keeps blinking and there's no sound. does anyone know why?
JJ
Posted By: dustin_parks79
Date Posted: April 15, 2004 at 3:44 AM
have you checked your, RCA cable's and RCA out puts on the back of your unit? "Reciver"? cause i was having the same prob. with a system the otherday. and that is what it turned out to be after playing with it all day trying and trying to figure it out, and returning items back to the store!
just somthing you can check out!
Posted By: jjl2191
Date Posted: April 15, 2004 at 4:08 AM
i did check RCA cables and output. the cables is brand new and the output seemed working when i connected to my home stereo. someone has suggested it indicates protection mode. is it possible?dont know much about this. nothing in the manual either.
JJ
Posted By: Ketel22
Date Posted: April 15, 2004 at 4:18 AM
just because the RCA's are brand new doesn't suggest they work properly have you tried several other sets?
Quad L Handyman services
Posted By: jjl2191
Date Posted: April 15, 2004 at 4:22 AM
i actually connected my car headunit to the home stereo with the same RCA cable. worked fine. posted_image
JJ
Posted By: robbie2883
Date Posted: April 15, 2004 at 10:26 AM
unhook the RAC's and speaker outputs from the amp so that just the power ground and remote are hooked to the amp and try to power it up. if it powers up the turn off and plug in RCA's and power up again. next the speaker wires. if any of these send it into protection then you've found your problem.
if its jammed force it - if it breaks in the process it needed to be fixed anyway
posted_image
Posted By: jjl2191
Date Posted: April 15, 2004 at 4:50 PM
i've tried that. still blinks. u think the problem is major? what do u think might have caused this problem? coz  when i tested it an hour ago it was fine but soon as i hooked it to my car it went dead. i'm pretty sure i didn't do anything stupid. all the wiring was done according to the manual. have u got a same amp?
JJ
