fading to non-fading preout
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=30456
Printed Date: April 18, 2026 at 12:01 AM
Topic: fading to non-fading preout
Posted By: goldenbrodie
Subject: fading to non-fading preout
Date Posted: April 15, 2004 at 8:04 PM
I've got a kenwood kdc-mpv619, its got front and rear preouts but no sub....is there any way to make one of them a non-fading preout? thanks
Posted By: customsuburb
Date Posted: April 15, 2004 at 8:30 PM
Your cd player might have the option to switch the rear outputs to non-fading. If not then the rear or front preamp outputs will be your only choice (you can always buy a good crossover, like the Audio Control 3xs, and get a sub output).
Posted By: stevdart
Date Posted: April 15, 2004 at 10:32 PM
I looked at the manual for this unit. It does not have the non-fading feature available.
Posted By: thepencil
Date Posted: April 15, 2004 at 11:23 PM
I am afraid stevdart that you are out of luck with the feature that you want with this unit. A Pioneer unit equivilent to yours does offer this feature. ------------- Be careful whose advice you buy, but be patient with those who supply it.
Posted By: forbidden
Date Posted: April 16, 2004 at 12:07 AM
A good solid bet is a outboard multicapacity unit like the Cadence QXR1. It is a line driver, crossover, phase shifter and has a dedicated dash mounted sub level control. It is a simple and easy upgrade for you. You need control of your sub system, another option would be one of the many Audio Control products.
------------- Top Secret, I can tell you but then my wife will kill me.
Posted By: thapimpfromchi
Date Posted: April 16, 2004 at 11:05 AM
hey, this cadence qxr1, how does it work? what do you connect it to?
------------- 1990 Honda Civic HB:
Clarion DXZ545MP H.U.
2- 6.5" Power Acoustik interiors
Diamond Audio 600.1 amp
Diamond Audio 15" M6MKII
Pyramid PB881X 4 CH. Amp
Date Posted: April 16, 2004 at 12:40 PM
i'm gonna pick up a crossover, when hooking up the power and ground can i use the same power cable for my amp and just soder on another end and split it to two lines, or do i need to run another power cablethanks
Date Posted: April 16, 2004 at 1:18 PM
Sorry for the delay guys, I'm on the west coast and I have to get the shop running before I can reply. The QXR1 is a for all intents and purposes a crossover. You would plug the front preout into it and then it splits it into High pass and low pass, line drives it, provides phase shifting for the subs and a dash mounted level control. So it has one pre in and two preouts, high pass for the front (which still fades) and low pass which does not. You would wire it in right before the front amplifier. For the second post it can be wired to an existing amplifier for power and ground.
Date Posted: April 16, 2004 at 6:19 PM
If you wanted in dash control plus an eq you could look at the audiocontrol Three.1
