thunder 8000
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=30520
Printed Date: April 22, 2026 at 7:54 AM
Topic: thunder 8000
Posted By: bruno71088
Subject: thunder 8000
Date Posted: April 16, 2004 at 9:08 PM
I was wondering what would happen if i wired my 4 ohm thunder 8000's to 2 ohms
Posted By: Ravendarat
Date Posted: April 17, 2004 at 12:34 AM
What would happen in what sense? That isnt really a very good way to word that question. I mean if you wire your subs in 2 ohms than its gonna put a larger load on the amp which will cause one of two things. It will either increase the power output or it will make it heat up and shut off or just blow up. What kinda amp are you using. As far as the subs go, essencially nothing will happen to them.
Date Posted: April 17, 2004 at 12:38 AM
thanks alot you completely answered my question as for the amp i just bought 2 pioneer 760 watt amps 1 for each of my subs.
Posted By: forbidden
Date Posted: April 17, 2004 at 1:24 AM
To me it sounds like you just opened a can of worms dude, no offence intended.
