1986 Nissan Micra Audio Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=30590
Printed Date: April 18, 2026 at 10:01 PM
Topic: 1986 Nissan Micra Audio Wiring
Posted By: tonyb1
Subject: 1986 Nissan Micra Audio Wiring
Date Posted: April 18, 2004 at 5:10 AM
Hi, I want to fit a stereo to a Nissan Micra (1986) but I'm not sure on the wiring.  I've managed to sort out the speaker connections  but the stereo needs a 12V Plus, a Ground and 12V memory connection.  I've found some wiring uner the dash were the old stereo used to be, but it all appears to be dead.  Can these connections be made with a straight run from the battery?  I'm at a total loss and would appreciate any help!  Thanks.  Tony.
Posted By: speedwayaudio1
Date Posted: April 18, 2004 at 5:15 AM
yes you can run off the batt. MAKE SURE YOU USE A INLINE FUSE.
Big Dave
Posted By: tonyb1
Date Posted: April 18, 2004 at 6:00 AM
Cheers dave, can I join the 12v memory and the 12V plus together?  I'm not sure about this memory wire?
Cheers
Posted By: kickerstang
Date Posted: April 18, 2004 at 7:06 AM
a head unit needs just a few basic wires to work.  you need a 12 constant, ignition, and a ground. now on most decks that would be the yellow, red, and black wires.  you asked about wiring it up straight to the battery which is possible but you would have constant power to your deck and run the risk of draining your battery.  you should look in your ignition harness and find a wire that is only "hot" when you start your car( it only gets power when your car is started). that would be your igniton(red) wire.  for your constant just find another wire that always have 12V, even when your car is not started.  then just find a good ground and you now have a working head unit
what!?!?! you want some??
Posted By: tonyb1
Date Posted: April 18, 2004 at 7:26 AM
Cheers.  One last question please (I know bugger all about electrics).  Can the negative terminal on the battery be used as a ground? or is it just a case of running the ground wire to a part of the chasis?   I have  a direct lead already available from the battery to the dash from both the Pus and Neg terminals.
Thanks again.
Date Posted: April 18, 2004 at 7:30 AM
just run the ground to the chassis, don't run it to the battery. you run the risk of picking up engine noise like that, plus it's a hell of a lot shorter just to ground it somewhere on the chassis
Posted By: tonyb1
Date Posted: April 24, 2004 at 10:54 AM
All fitted and working guys, cheers.
