L7 12
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=30603
Printed Date: April 19, 2026 at 1:41 AM
Topic: L7 12
Posted By: flatulatta
Subject: L7 12
Date Posted: April 18, 2004 at 12:34 PM
i think ive got a bit of a problem with my sub... everytime it hits it sounds like rattling glass.... no its not the glass in my car b/c ive opened up the back and put my ear right near the sub and its def coming from the sub.... i was told in town that its a warped voice coil what ever that is... any help on this matter would be appreciated im just wondering if theres any way to tell wuts wrong with it....if there is anything
Posted By: forbidden
Date Posted: April 18, 2004 at 5:54 PM
Chances are that your speaker is in the final stages of sss, smelly speaker syndrome. If it is not under warranty, then a new sub is in your future. Sorry to hear the news.
Date Posted: April 18, 2004 at 6:04 PM
the subs around 2weeks old....
Date Posted: April 18, 2004 at 6:07 PM
btw.....i only have 600w amp on it with gains set at almost min... no bass boost... 80hz crossover... i mean from the driver/passenger seats it sounds quite nice... but... when i go back and listen to it....sounds weird... perhaps ill record it and post it
Date Posted: April 18, 2004 at 6:14 PM
You may still have been clipping the signal going into the amp, thus even with your gains set "safe" they may have been amplifying a dirty signal. A sub will generally play a normally unnoticeable amount of distortion along with your music. If the noise is audable up front then there is a definite problem, but as you pointed out it is only from the cone itself. Maybe it's just your ears being spanked by excessive bass, hehe. It does sound to me like there is a definite issue with the sub. I would see if you can try another and see what the results are.
Date Posted: April 18, 2004 at 6:22 PM
i talked to a guy at a local shop he said if i went by later in the week he could test it for me so imma try that i hope its nothing realy big otherwise im def switchin to a dif sub... this is my 2nd L7...how would i be able 2 tell if it was a warped voice coil?? and how would i have caused this?
i talked to a guy at a local shop he said if i went by later in the week he could test it for me so imma try that i hope its nothing realy big otherwise im def switchin to a dif sub... this is my 2nd L7...how would i be able 2 tell if it was a warped voice coil?? and how would i have caused this?... could
Date Posted: April 18, 2004 at 6:23 PM
i talked to a guy at a local shop he said if i went by later in the week he could test it for me so imma try that i hope its nothing realy big otherwise im def switchin to a dif sub... this is my 2nd L7...how would i be able 2 tell if it was a warped voice coil?? and how would i have caused this?... could it possibly be my box??? i have a 2cuft box?? could it be that the pressure in the box is to low and the sub is trying 2 push nothing?
Date Posted: April 18, 2004 at 6:25 PM
^^^^ sry... triple post.....real quick question... what kinda equipment would i need to check this?? just a voltmetr or something else?
Date Posted: April 18, 2004 at 6:29 PM
I am not a Kicker dealer but here goes, I am not a Kicker dealer but here goes, I believe that the Kicker uses a Kapton former on this sub. Kapton is a high temperature Dupont plastic, plastic of any kind can warp when given excessive amount of heat that cannot be removed. Even aluminum can warp if the circumstances are extreme enough. Heat is the natural byproduct of producing power, be it is a sub or an amp. Heat is the number 1 enemy of a sub for if it cannot get rid of it, the dreaded sss makes it's presence felt. This is usually cause by the wrong gain setting, excessive bass boost, excessive level control or Epicenter, clipping of input signal to the amp and of course not allowing the sub to cool down after long hard use and finally flawed design (read as being used for intents beyond it's application).
Date Posted: April 18, 2004 at 6:30 PM
If your box is out to lunch it will affect the power handling of the sub. Is it ported or sealed?
Date Posted: April 18, 2004 at 6:35 PM
dont know wut out to lunch means... but its a little smaller than 2cuft and sealed.....
