alternator
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=30794
Printed Date: May 16, 2026 at 2:14 AM
Topic: alternator
Posted By: 97neon
Subject: alternator
Date Posted: April 21, 2004 at 12:30 PM
hey guys, i have a 1997 neon, iw ill be running a memphis mc1000d and a pioneer 4 channel amp, i have a yellow top battery, what size alternator will i need,
Posted By: bfog99
Date Posted: April 21, 2004 at 1:13 PM
under the assumption that you will be running the memphis at 1 ohm, it will put out 1100 watts RMS. This alone is roughly 86 amps. I would look into an alt that is at least 120, closer to 150 amps.
Posted By: 97neon
Date Posted: April 21, 2004 at 1:15 PM
ok, cool, i was gonna get 160, bu, what if i ad a another mc1000d which i will probably do, will 160 amps be enough
Posted By: 97neon
Date Posted: April 21, 2004 at 8:17 PM
so would 160 amps be enough?
Posted By: Ketel22
Date Posted: April 21, 2004 at 8:59 PM
well if you have two amps pulling about 172 amps from your altenator it leave about -12amps for your car to draw from if you got the 160 amp alt. and the second amp. ------------- Quad L Handyman services
Posted By: bfog99
Date Posted: April 21, 2004 at 11:38 PM
if you plan on adding another memphis amp, look into something in the general vacinity of 200 amps.
Posted By: speedwayaudio1
Date Posted: April 22, 2004 at 12:49 AM
yes go ahead and get a 200amp alt you will be glade you did.
------------- Big Dave
Posted By: Ketel22
Date Posted: April 22, 2004 at 12:52 AM
maybe the 210amp alt. just for a little over head. 200amp alt. will probally be cutting it a little close if you get the second amp.
Posted By: 97neon
Date Posted: April 22, 2004 at 2:04 AM
ok, cool, i prcied one out in canada wher ie live, and they want 280 for a 160 amp alt, is that a lot? thats canadian prices
Posted By: 97neon
Date Posted: April 22, 2004 at 1:01 PM
is this a good price?
Posted By: 97neon
Date Posted: April 22, 2004 at 8:43 PM
Posted By: customsuburb
Date Posted: April 22, 2004 at 9:07 PM
Sounds like a pretty good price to me.
