Memphis 16-MC1000D Amp THD?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=30803
Printed Date: May 16, 2026 at 12:31 AM
Topic: Memphis 16-MC1000D Amp THD?
Posted By: Sebastian018
Subject: Memphis 16-MC1000D Amp THD?
Date Posted: April 21, 2004 at 2:28 PM
HI, IM planning to get a MEMPHIS 16-MC1000D which im planning it to run at 1 oh, rated at 1 ohms 1100 Rms, The THD is 1.10%, Is that good or bad, how will make a difference?>
thank you
Posted By: DYohn
Date Posted: April 21, 2004 at 2:40 PM
That is quite high, but it is also typical for a 1-ohm rating. As the impedence load goes down, noise goes up and distortion goes way up. Memphis makes very good equipment, but it (like almost all car audio equipment) is designed to operate at 4 ohms for best sound quality performance. ------------- Support the12volt.com
Date Posted: April 21, 2004 at 10:15 PM
What 1 ohm amplifier that could give me like 1200W rms or 1100 rms, Its good.
thank you
Date Posted: April 21, 2004 at 11:32 PM
I was looking at these amps which are 1 ohm Stable from these amps which one would be the best to get.
MEMPHIS 16-MC1000D (1100x1 at 1 ohm)
MA Audio HK-2000D (1500W @ 1 Ohm)
Kicker Kx1200.1(1200 W RMS x1 @ 1ohm )
Audiobahn A2200HCT (1 Ohm Mono: 1600 X 1 Watts)
Audiobahn A1300HCT (1200 x 1 Watts RMS @ 1 Ohm)
Lightning Audio X1.1000.1D( 1000 x 1 at 1 ohm)
PLease let me know which one would be the best.
Posted By: DYohn
Date Posted: April 22, 2004 at 8:18 AM
On that list, the Memphis is the best quality, best sounding amp by far in my book. If you are planning to run 1000 watt subs at 1 ohm, then you are going for SPL, so why worry about THD numbers? All you'll get is boom anyway... ------------- Support the12volt.com
Date Posted: April 22, 2004 at 12:00 PM
yes you are right..and not from that list which one is better than memphis. that is 1ohm stable...
