Intrepid 94 es with infinity oem system
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=30957
Printed Date: May 11, 2026 at 8:38 AM
Topic: Intrepid 94 es with infinity oem system
Posted By: Type S
Subject: Intrepid 94 es with infinity oem system
Date Posted: April 24, 2004 at 5:46 PM
Does anybody know how to make this system sound better using the oem amp.  I have a Kenwood head unit and it used to sound much better with the old system.
All the hook ups are made properly.  I am using the infinity amp with the Kenwood unit.
any suggestions anybody?
thanx a lot.
If something is not working as planed, Check your ground ;)
Posted By: customsuburb
Date Posted: April 24, 2004 at 5:52 PM
The interface you should be using with that factory amp should have a gain control on it. You should try adjusting this. You could bypass the factory amp if you want to run new wires, but i would just buy some new speakers and bypass the factory amp (and maybe add an external amp also).
Posted By: Type S
Date Posted: April 25, 2004 at 6:07 PM
Thanx a lot i will try that and reply to you when it done or when my client decides to do it
Type S
www.types.ca
If something is not working as planed, Check your ground posted_image
Posted By: raydawg357
Date Posted: April 26, 2004 at 7:39 AM
If you decide to buy new speakers, you don't have to run new wire.  At each speaker, there are 6 wires,  two of them are coming directly from the radio.  Find these, cut,  and connect them directly to the new speakers.
Do it right the first time
