Sub and Amp questions
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=30979
Printed Date: May 10, 2026 at 11:10 PM
Topic: Sub and Amp questions
Posted By: 87BMw325es
Subject: Sub and Amp questions
Date Posted: April 24, 2004 at 10:02 PM
I have a 400 watt 4 channel Jensen amplifier that I am going to have installed in my 1987 BMW 325es. I don't know that much about car audio, so forgive me if my questions are stupid.
1. Is it necessary to buy a sub to go along with the amp in order for it to work? Or will it just make it sound better if I get a sub?
2. If I do buy a sub to go along with my amp, what would be a good brand and wattage? I am looking to spend anywhere from 100-300 dollars max.
Posted By: stevdart
Date Posted: April 24, 2004 at 10:21 PM
1.  You have to have some speakers connected to the amp to get any benefit.  ;)  You didn't mention speakers.  Are you replacing the factory located speakers?  And, no, it's not necessary to have a sub for the amp to work.  But a sub will fill out the sound with the deepest bass tones.
2.  First, need to know what speakers are already planned for use with that amp.
Date Posted: April 24, 2004 at 10:28 PM
Sorry I forgot to mention my speakers. I do have speakers already in my car. There are 2 factory speakers in the front side door panels, then the person who I bought the car from put in 2 speakers in the back. I'm not sure what kind of speakers they are, since there is no brand name on them. So should I probably know the wattage of my speakers before buying a sub?
Date Posted: April 24, 2004 at 10:30 PM
Oops, I also forgot to say that I am not replacing the speakers are currently have...or atleast I don't want to if I don't have to.
Posted By: stevdart
Date Posted: April 24, 2004 at 10:46 PM
What is the reason for installing the amp?  To blow out the factory speakers?  You would have about 50 watts going to each speaker that was built (15 years ago) to accept probably about 10 watts.
Is the amp being installed by a pro?  And what is his recommendation?
Posted By: stevdart
Date Posted: April 24, 2004 at 11:14 PM
Sorry, that sounded harsh :)  I recommend that you plan on purchasing replacement speakers for the front doors.  Check Crutchfield for "what fits my car".  Then shop the internet for a good deal on a pair, 50 watt RMS.  Hook those up to two channels of your 4 ch amp.  A good sub that you can get cheap is the Cerwin-Vega from millionbuy.com.  About $50.  If you can build the enclosure for it, its a great deal.  An easier solution would be to buy this kit  https://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=260-580  for the subwoofer.  It could be connected to the 2 other channels.
There are other necessary things, too.  The radio (head unit) is usually replaced as well.  But original head units sometimes are kept in place and an adapter is used to transfer the music signal to the amp.
Is that a new amp?  Find out all you can about it, impedence rating, bridgable?  Spend some time reading through posts on this forum and you'll find a lot of info.
Date Posted: April 24, 2004 at 11:40 PM
I am having a professional install the amp for me. There's no way I could do it, lol. I will strongly consider buying new front speakers and those subs you mentioned look like great deals.
Thanks for all the helpful tips and info!
Posted By: customsuburb
Date Posted: April 25, 2004 at 9:01 AM
I would definitely consider buying some good inexpensive coaxials to replace your current speakers. Look at good brands like infinity, JBL, MB Quart, and Boston acoustics. Try listening to some of these brands of speakers and then buy what sounds best to you. The JBL GTO 506C is a good inexpensive component set that will fit in the factory location up front.
