Need help fixing install
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=31001
Printed Date: May 10, 2026 at 10:56 AM
Topic: Need help fixing install
Posted By: ottawaLX
Subject: Need help fixing install
Date Posted: April 25, 2004 at 11:14 AM
Hi everyone, I recently got my stereo installed at a recent shop, while I knew the shop had a poor rep they gave me a really good price on an amp I just couldn't pass on. Here is what I have: a used pair of infinity perfect 12.1 subs in a ported box, a brand new pair of Infinity reference series component speakers (6000cs), and a brand new Clarion APX 640.2 amp. The speakers are used and a little beat up but when I bought them about a month or so ago they hit really hard. The amp was installed with a 4 gauge wire kit. It sounds alright I guess but there is barely any bass. Also I can hear a buzzing sort of sound when there is a pause in the music. When the guy demo'd my car after the install at first he was curious why there was no bass so he talked to the installer who apparelently told him my subs are blown, and that they are "flexing too much and all over the place." At the time I didnt know what to think so I just basically just accepted it as being that. I know have come to believe that my subs arent blown 'cause if I turn them off I still can't even even crank just my component speakers. I have got it to sound a little clearer since then but I am still fairly new to all this so I still dont really know what I'm doing at this point. Any advice would be greatly appreciated. thanks
Posted By: stevdart
Date Posted: April 25, 2004 at 11:22 AM
The installer thought the subs were blown but the shop installed them anyway. Boy, that is one helluva operation.
Posted By: ottawaLX
Date Posted: April 25, 2004 at 11:24 AM
Oh I also forgot to add when the bass "hits" the lights in my car dim, my dad hooked up a meter yo my battery it is at about 14V normally, but when they hit it drops down to about 13V or so
Posted By: davidwp13
Date Posted: April 25, 2004 at 12:04 PM
You need to pull EVERYTHING and start over BEFORE you fry something, I am new at this too but with the diagrams on this site and the help you can get you can do it yourself. I wired an advanced security system with help I got here and everything works great. Without knowing what they did you really do need to start over just like a NEW install. GOOD LUCK ------------- David
Posted By: bryceyaworsky
Date Posted: April 25, 2004 at 12:46 PM
pulling everything could be a good a way to go, but may not be necessary. Another option would be to go elsewhere and get it fixed if you're not comfortable doing yourself. Anyhow, I'm guessing that you're running that clarion for the subs? That would be 150 rms to each 12"? If that's the case it sounds like a polarity issue at the subs. You may want to check and make sure that + goes to + and - to -. Something else to consider is the gain setting on the amp: make sure it's set right. Other than that, I'd need some specifics like power to give you a better suggestion. The buzzing is ground noise. This one can be much harder to figure out if you didn't do the install. Are the amps mounted to the car chassis? If they are, you're asking for ground noise. Again, I'd need to see pics or something to give you better advice. The dimming shouldn't be a problem for you if it's dropping to 13V, but you should be checking your voltage at the amps instead of the battery for a better idea of voltage. Keep in mind that if you put too much strain on the alternator you'll end up replacing it a few times like I've done in the past. I should note that blown subs don't work at all, and are identified by a charred smell as well as a stiff cone. When you push the cone there will be no movement like that of a working sub.
Posted By: dudek38
Date Posted: April 25, 2004 at 7:44 PM
listen to bryceyaworsky. or print his reply out and take it to the installers and say, "here, please fix it."
------------- owner of
Motion Marine & Car Audio
the florida keys
Posted By: Alpine Guy
Date Posted: April 25, 2004 at 8:32 PM
There is to ways a speaker can be blown, 1 is a full on seizure, and 2 is a partial blow where it makes popping noises, most noticed at low volumes, and by tapping the surround of the speaker. If your hearing crisp bass, just not loud, , then go bitch. If they don't fix it, tell them to take it out, and get your money back, and get it installed elsewhere. Give them the car for the day, so they have lots of time to do the "little" things.
------------- 2003 Chevy Avalanche,Eclipse CD7000,Morel Elate 5,Adire Extremis,Alpine PDX-4.150, 15" TC-3000, 2 Alpine PDX-1.1000, 470Amp HO Alt.
Date Posted: April 25, 2004 at 8:34 PM
And im guessing the shop was in ottawa?? What shop was it? PM it to me, don't post it on here, if the shop see's it they can sue. ------------- 2003 Chevy Avalanche,Eclipse CD7000,Morel Elate 5,Adire Extremis,Alpine PDX-4.150, 15" TC-3000, 2 Alpine PDX-1.1000, 470Amp HO Alt.
Posted By: flynntech
Date Posted: April 25, 2004 at 11:00 PM
How would they be able to sue? They messed up an install, as long as it's not a LIE it's perfectly ok ...imo although I'm not a lawyer....I'd laugh at anyone who tried to sue me....there is NOTHING they could possibly take from me besides a day or two in court. I wouldn't go 'ripping everything out', that seems like a big waste of time. It's an audio install, how much could possibly go wrong? When I fix a circuit board, I don't desolder everything there and replace each component one at a time. I just ISOLATE the fault and CORRECT the problem......hence the 'tech' in my screen name. If these guys need a WHOLE DAY to fix 'little things' there is just simply NO HOPE FOR THEM.............the should all retire from car audio and open up a bakery. I wouldn't even ask for a refund, they won't give it to you anyways. Just tell EVERYONE about them. I know that there is no law against that in the states.....it's our first amendment. Running a crappy stereo shop doesn't grant you any special rights, if you do me wrong, I'll get you back ten times worse! Good luck!
Posted By: thapimpfromchi
Date Posted: April 26, 2004 at 3:07 AM
hey man, you said they hit good first, then they stopped hitting?
------------- 1990 Honda Civic HB:
Clarion DXZ545MP H.U.
2- 6.5" Power Acoustik interiors
Diamond Audio 600.1 amp
Diamond Audio 15" M6MKII
Pyramid PB881X 4 CH. Amp
Posted By: ottawaLX
Date Posted: April 26, 2004 at 12:51 PM
Ok well I have figured out what was wrong and I fixed it. The amp was bridged but the subs weren't hooked up to be run off of a bridged amp, so I switched to amp to two channel mono and ran the wires accordingly. Which now brings me to my next question how should I wire up the subs within the box so I can run the amp bridged?
Posted By: stevdart
Date Posted: April 26, 2004 at 7:57 PM
The problem is the match up between your 2 subs and your amp. The subs are single voice coil 4 ohm (correct me if i'm wrong). They can be paired by wiring in series to each other. That presents an 8 ohm load to the bridged amp. The alternative wiring for 2 4 ohm subs is parallel. You can't do that because the impedence of 2 ohm bridged is too low for the amp. So, in reality, the subs are going to get one half the power you expect them to get.
------------- Build the box so that it performs well in the worst case scenario and, in return, it will reward you at all times.
Posted By: ottawaLX
Date Posted: April 27, 2004 at 10:58 AM
So then what you are saying is that for optimal performance I would have to hook the subs up as per the above diagram? And then bridge my amp and run only 1 set of wires to the terminal leaving the other terminal not hooked up to anything right?
Posted By: aggie altima
Date Posted: April 27, 2004 at 2:41 PM
Isn't 8 ohm mono the same as 4 ohm stereo, which would mean no difference in performance between bridging @ 8 ohm mono and using 2 channels @ 4 ohms stereo?
------------- Jon Don't like rockford subs? Then don't look at my car =)
Posted By: Ravendarat
Date Posted: April 27, 2004 at 3:55 PM
yes, its the same thing
------------- double-secret reverse-osmosis speaker-cone-induced high-level interference distortion, Its a killer
