Mach 460 Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=311
Printed Date: May 07, 2026 at 11:17 AM
Topic: Mach 460 Wiring
Posted By: ott7283
Subject: Mach 460 Wiring
Date Posted: April 12, 2002 at 10:07 PM
Can anybody help me with the wiring descriptions coming from the radio for a 1999 Ford Mustang Convertible with a Mach 460 system?
Posted By: pushrodv8
Date Posted: April 13, 2002 at 12:51 PM
If you could let me know what it is that you are trying to do, I could probably get that information. Let me know.
Posted By: ott7283
Date Posted: April 13, 2002 at 1:42 PM
I trying to add an additional amp for a pair of subs and I want to tap off the signal for the rear speakers.
Posted By: jeffchilcott
Date Posted: April 13, 2002 at 5:21 PM
If you want to tap off the rear speakers just tap into them under your rear window deck...this will save you time and wire.....shouldnt it? If you have more questions post and I will reply....Jeff
------------- 2009 0-1000 Trunk WR 154.0DB 2009 1001+ Trunk WR
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Posted By: ott7283
Date Posted: April 13, 2002 at 9:54 PM
I thought about using the wires that go into the amp for the rear speakers, but I only saw three wires. It didn't quite make sense, unless there is only 1 ground for both the right and the left.
Posted By: lowpro1
Date Posted: April 19, 2002 at 2:13 AM
I would not suggest trying to tap off of the rear speakers, because the 460 set-up is powered by a single 10-20w amp for both of the rear speakers. I would suggest leaving the rear speakers alone and if you want to run an loc then you might want to pull the drivers side rear quarter panel (interior) and tap off of the wires that lead to the amp and speakers. You should find them in a small bundle (about 6-10 wires) leading into the trunk. KC Low Pro Customz owner/ installer
Posted By: spankybh
Date Posted: September 17, 2002 at 2:15 PM
A guy I work with said, that the signal in the rear, b4 the amp is weak and distorted. He ended up replacing his whole sys. Its hard to convince customers to do the same. I'm still looking for a good signal...need help.
Posted By: crroush
Date Posted: September 17, 2002 at 3:51 PM
You can buy a kit that is made by PAC, www.go2pac.com, and it will interface directly between the head unit(factory) and the wiring harness. It will provide you 2 low level inputs and 1 remote wire output so you can hook up additional amplifiers. Craig
Posted By: wvsquirrel
Date Posted: September 28, 2002 at 9:27 PM
This sight has alot of info about the MACH460, it's where I started looking: https://www.flemworld.com/95/mach.html This site has a good breakdown of the wire harness for the radio: https://carstereohelp.com/wireharnessFord1.htm ------------- Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
