Ohms?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=31353
Printed Date: March 19, 2026 at 11:57 AM
Topic: Ohms?
Posted By: preluder14
Subject: Ohms?
Date Posted: April 30, 2004 at 7:09 PM
OK, i am aware that this is very basic and that i should know this but what exactly is the difference between 4 ohm and 2 ohm subs? From the Alpine specs, the SWR-1221D at 2ohms is exactly the same as the SWR-1241 at 4ohms. Is the sound any different?
Posted By: stevdart
Date Posted: April 30, 2004 at 7:19 PM
The reason there are all the different impedence configurations on subs is because you need to arrive at a final ohm impedence at the amp that the amp can handle.  Other than single voice coil or dual voice coil, 2 ohm or 4 ohm, the subs are the same.  Post your intended system for help on selecting the right subs.
