How to wire 3 4ohm subs to 4 channel amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=31359
Printed Date: March 19, 2026 at 10:15 AM
Topic: How to wire 3 4ohm subs to 4 channel amp
Posted By: FTW444
Subject: How to wire 3 4ohm subs to 4 channel amp
Date Posted: April 30, 2004 at 9:30 PM
I have 3 subs not dvc!!!    Want to wire them to a 4 channel amp ne help would be appreciated
FTW
Posted By: stevdart
Date Posted: April 30, 2004 at 9:38 PM
Why?
Posted By: forbidden
Date Posted: April 30, 2004 at 11:08 PM
Make sure each sub is in it's own enclosure, wire 1 up to channel 1, one up to channel 2 and the 3rd to the bridged outputs of channel 3 and 4. Thus the reason for the separate boxes. One sub will get more power than the others but if the gains and crossover points are set correct all should be fine.
Posted By: Ketel22
Date Posted: April 30, 2004 at 11:33 PM
you could also set it up in "3-channel" mode if the amp is capable of it.
Quad L Handyman services
Date Posted: April 30, 2004 at 11:45 PM
Ketel, it must be past your bedtime, that's what I suggested. posted_image And make some room in your PM inbox.
Posted By: Ketel22
Date Posted: April 30, 2004 at 11:55 PM
i was thinking of another way sorry i didnt express what i ment. i was thinking, bridging channels 1 and 2 for a sub, bridging channels 3 and 4,  and hooking the third sub up to channels 2 and 3..... sorry about the PM box i didnt know i had ne thing in it......
