2 amps on 2 channel head unit
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=31391
Printed Date: March 18, 2026 at 3:30 PM
Topic: 2 amps on 2 channel head unit
Posted By: jodtan
Subject: 2 amps on 2 channel head unit
Date Posted: May 01, 2004 at 1:34 PM
I like to add another amp to my headunit to drive another set of speakers. I hooked up my amp with the RCA output of my headunit. Where do I hook up the other amp? Headunit is only 2 channel.
jod
Posted By: kickerstang
Date Posted: May 01, 2004 at 1:36 PM
do you mean the head unit only has one set of RCA's? what do you mean 2 channel
what!?!?! you want some??
Posted By: forbidden
Date Posted: May 01, 2004 at 3:36 PM
Sounds like the cd player has on ly 1 set of preouts. Does either amp have a set of pass through rca outputs?
Posted By: DYohn
Date Posted: May 01, 2004 at 4:17 PM
It'd be nice to know what make/model head you are talking about...
Posted By: netboy
Date Posted: May 01, 2004 at 5:38 PM
maybe get an external crossover with 1 set of inputs and 2 sets of output
Memphis MC-1300
2 12" JLw6v2
Diamond audio M3 6x9
Diamond audio M3 5.25 components
Audio control Matrix
Carputer
Posted By: jodtan
Date Posted: May 01, 2004 at 9:04 PM
yes, headunit only have one pair of RCA pre-out.
jod
Posted By: customsuburb
Date Posted: May 01, 2004 at 9:18 PM
You can either split the output or get a good crossover from someone like audio control. Their 24xs would be a good choice for just two amps (like a sub amp and an amp for your mids and highs).
Posted By: Sweekster
Date Posted: May 02, 2004 at 1:56 AM
A crossover or eq will give you a better sound quality  because it'll give your amps a cleaner signal.  If that is not in the works then splitting the signal with a couple Y adapters will do the trick.  But if you plan on doing this so you can run mids and highs  (interior speakers) with another amp , then your head units fader control is useless.  You could add a remote fader to control that part and be ok.  But I say save your money for a crossover or eq (or both) if you want better SQ .
Duane...
If you think you're confused, imagine how you feel.   posted_image
