3 type S subs with 1 PPI 2150
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=31422
Printed Date: March 17, 2026 at 2:39 PM
Topic: 3 type S subs with 1 PPI 2150
Posted By: Jay22
Subject: 3 type S subs with 1 PPI 2150
Date Posted: May 01, 2004 at 9:55 PM
I hooked two up so far untill i get another amp for the third.
I bought two 4ohm dvc and one 2ohm dvc.
Do you think i could run the 4 ohm dvcs into one channel @ 2 ohms and the other 2 ohm sub into the other channel @ 2 ohms?
If I can will it sound good. The amp puts out 300Rms per channel or 600RMS bridged.
Posted By: DYohn
Date Posted: May 01, 2004 at 10:22 PM
First of all, you cannot create a 2-ohm load with a DVC 2-ohm sub.  This sub can only be wired at 1 ohm or at 4 ohms.  And no, you should not mix and match like this.  Let me see if I can explain it in laymens terms:  If you were able to wire one sub at 2 ohms on one channel of an amp and two subs to create a 2 ohm load on the ohter channel, the amp would not care, but the single sub will be utilizing all the output from one amplifier channel and therefor be twice as loud as the other side, where 2 subs are sharing the power.  Does this make sense?
All your subs should be the same for proper balance if you intend to run them off the same amp or at the same crossover point.
