CD Player shorting 7.5 amp fuse
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=31647
Printed Date: March 14, 2026 at 4:47 PM
Topic: CD Player shorting 7.5 amp fuse
Posted By: Ethan
Subject: CD Player shorting 7.5 amp fuse
Date Posted: May 05, 2004 at 4:48 PM
Hi I'm new to car audio installation and have attached the power wires according to the12volt.com's wiring specifications (haven't attached speaker wires yet) and for some reason when I try to turn it on it shorts the 7.5 amp fuse.  My car is a 1991 Honda Accord.  What would you suggest me doing to get this sucker working?
Posted By: kgerry
Date Posted: May 05, 2004 at 5:20 PM
are the speaker wires touching together or any metal at all in the car?    does it only blow the fuse when you turn it ON or when you apply power?
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: Ethan
Date Posted: May 05, 2004 at 6:05 PM
I'm not for sure... I just assumed that it wouldn't matter about the speaker wires since they weren't going to be connected to anything.
HAHAHA I just tried it making sure that none of the speaker wires were touching and it worked!!!  Thanks!
Posted By: forbidden
Date Posted: May 05, 2004 at 8:20 PM
Cringes....shakes head.... throws hands in the air.... turns and walks away.... continues to shiver...
Posted By: customsuburb
Date Posted: May 05, 2004 at 8:33 PM
lol! posted_image
Posted By: Ethan
Date Posted: May 05, 2004 at 10:22 PM
ok another question.  I attached the two antenna wires together but it still won't go up when I turn the cd player on.  Is there some weird configuration that I need to add for it to work?  I know that when i touch the constant + to the antena wire that it goes up when the car is on.
Posted By: Ravendarat
Date Posted: May 05, 2004 at 11:21 PM
Is it when you are on cd or radio, becuase the antenna wont go up if you have it on cd.
Posted By: thapimpfromchi
Date Posted: May 05, 2004 at 11:24 PM
power antenna only goes up when the am/fm is being used. Pop in a cd, and the antenna retracts. Switch to the radio. Make sure the antenna works altogether.
1990 Honda Civic HB:
Clarion DXZ545MP H.U.
2- 6.5" Power Acoustik interiors
Diamond Audio 600.1 amp
Diamond Audio 15" M6MKII
Pyramid PB881X 4 CH. Amp
Posted By: Ethan
Date Posted: May 06, 2004 at 12:21 AM
Yeah it wouldn't go up even on radio.  I know the antena works because i could test it by just touching the two wires together.
Date Posted: May 06, 2004 at 12:34 AM
Sounds like the wire on the deck doesnt work, check it with multi meter or a test light to ensure the output from the deck works
Posted By: kgerry
Date Posted: May 06, 2004 at 9:34 AM
you dont have the trunk open do you? the accords, vigors, etc.  have a circuit that will drop the power antenna when the trunk latch is sprung, so the optional trunk lid spoiler doesnt snap off the antenna
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
