Better sound
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=31737
Printed Date: March 14, 2026 at 1:00 AM
Topic: Better sound
Posted By: PimpVan
Subject: Better sound
Date Posted: May 06, 2004 at 9:45 PM
I have 2 kicker comp 12" subs.I just had a question as if i was to flip the subs to where the magnet is fasing out, is that going to change there sound at all.Like will they hit harder or not harder, or would it stay the same and nothing change. thanks
Posted By: xTimx
Date Posted: May 06, 2004 at 10:10 PM
well i had my 2 12" MA audio 12D6 subs in a 3 cu ft sealed box. and they pounded hard. but when i inverted them, they actually put out more spl. this way i have them now does 139.6 on the SPL scale. just remember to reverse the polarity. some people have diff opinions on inverting subs, mainly cause of the look. luckily for me the 12"s i have, have a chrome basket with a blue magnet and they look awesome!
------------- xTimx
Posted By: DYohn
It will not change the sound at all if you put them in the correct enclosure. If you simply invert them in theur current enclosure, the sound will likely lose definition and become more "flabby." ------------- Support the12volt.com
Posted By: markcars
Date Posted: May 06, 2004 at 10:17 PM
You'll probably be using a bigger box (to protect the protuding magnet) besides keeping within the required specs such as volume of box etc. If space is not a concern, go for it. What kind of vehicle are you using the sub in? Are you using a ported enclosure or non? That would also make a difference.
Posted By: Alpine Guy
Date Posted: May 06, 2004 at 10:32 PM
The only way it would make a difference is by when you invert the sub , more airspace in the box is freed up for the sub to move more freely, but i can guarantee only electronic testing equipment will be able to see the difference.
------------- 2003 Chevy Avalanche,Eclipse CD7000,Morel Elate 5,Adire Extremis,Alpine PDX-4.150, 15" TC-3000, 2 Alpine PDX-1.1000, 470Amp HO Alt.
Posted By: markcars
Date Posted: May 07, 2004 at 6:47 AM
If the box is ported, would that not allow the sub's cone to move "freely" since there is no "sealed" air volume in the box?
Posted By: DYohn
Date Posted: May 07, 2004 at 8:22 AM
Inverting a speaker does nothing to allow the cone to "move more freely'." What it can do is increase the airspace in the enclosure, ported or sealed or otherwise. When you invert a speaker, you 1) remove the basket and magnet assembly from the inside of the enclosure so it is no longer taking up space, and 2) add the volume inside the cone to the inside of the enclosure. These things make the effective air volume larger and this must be taken into account in the enclosure design. If an enclosure is designed for conventional mounting and then the woofer is inverted, the enclosure size increases by somewhere between 0.1 and 0.25 cuft (or more) depending on the woofer. This means the performance of the enclosure changes. Why all the questions about inverted speaker mounting I wonder? The ONLY reason to do this that I can think of is for looks (unless you are building an isobaric enclosure, I suppose.) ------------- Support the12volt.com
Posted By: forbidden
Date Posted: May 07, 2004 at 1:15 PM
Noticed alot of posts about this topic, might be something to cover with a sticky.
------------- Top Secret, I can tell you but then my wife will kill me.
Posted By: xTimx
Date Posted: May 07, 2004 at 2:33 PM
yes that too Rob and the gain Q's are coming in like crazy! i suggest you make both of them sticky
------------- xTimx
Posted By: PimpVan
Date Posted: May 09, 2004 at 9:21 PM
Thanks everyone for your post and to let some know its going in the back of my grandvoyger or what everyone calls a miniVan.I like the van though because of ALL THAT AIR SPACE i get to play with. It will be a sealed box,and i do know about the polarity thing.And i heard that when i invert them i will have to make a much smaller box for them.
