? on Kicker 12L5s
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=31800
Printed Date: April 18, 2026 at 11:07 PM
Topic: ? on Kicker 12L5s
Posted By: SupaCrazy
Subject: ? on Kicker 12L5s
Date Posted: May 08, 2004 at 2:22 AM
I have 2 12" L5's i want to put under the backseat of my 2004 ex cab Silverado. I have designed the box and it works out to be about 1.22cuft of air space per sub, but i dont know if the displacement of the sub will off set that or not, so the question is based on the info that came with the subs, it says that they need .88cuft at the min, but it says that the displacement is already worked in. thats where im confused. the displacementfr the 12"L5 is 131.1CuIn. Any help would be great thanks.
Jimmy
Posted By: Ketel22
Date Posted: May 08, 2004 at 2:49 AM
for an extended cab you should be able to get more air space than that? did you limit the size smaller than the seat it self was... i would suggest trying to achieve at least another 0.75 cuft of airspace before you try too much with those.
Quad L Handyman services
Date Posted: May 08, 2004 at 2:57 AM
i am trying not to have the box hanging out from under the seat, so i only have about 8" of height and 13" of depth the width is 58" and it is going iver a hump. I can use polly fill to get an extra bit of air space if needed, but i just looked at the website again, and the min box size is even given 13 x 13, 13 x 11.5, 11.5 x 11.5, that only comes out to .88cuin of air and thats not taking in the sub size. so i guess that i should be fine.
Posted By: stevdart
Date Posted: May 08, 2004 at 10:06 PM
They do take into account the sub displacement when they give you that minimum number.  So you can make the box  at .88ft3 total air, fill with polyfil, and be fine.  The actual air after the speaker is mounted would then be the difference of .88 less .07586 (speaker displacement) = .804
