Custom Subwoofer Box
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=31979
Printed Date: April 13, 2026 at 8:03 AM
Topic: Custom Subwoofer Box
Posted By: markcars
Subject: Custom Subwoofer Box
Date Posted: May 11, 2004 at 10:33 AM
I want to build a custom box for my Alpine R 12" Sub, that will fit in my Highlander with least space intrusion in the trunk and most aesthetic/factory look. What kind of materials should I use to get best sound quality? I don't care about spl. I have too much of it.
Plastic? Wood? Plexiglass? Also does the shape of the box matter? I know that the volume matters, such that I should try to stay within the required cft requirements. So if I have the right volume (cft) of air in the box, and the shape is not a cube, will it sound good?
Any info would be appreciated, preferably from knowledgeable folks. Thanks.
Mark
Posted By: doc t
Date Posted: May 11, 2004 at 10:41 AM
go to the forum pull down menu and select the "fiberglass & interiors" site and re-post. first read past posts and your question should be answered.
Posted By: Ketel22
Date Posted: May 11, 2004 at 12:22 PM
use a combinatino of mdf and fiberglass to create an enclosure that suits you. the size doesn't matter and fiberglass and mdf are both great materials to build enclosures with. just make sure you get the internal volume correct.
------------- Quad L Handyman services
