loss of bass
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=32146
Printed Date: April 09, 2026 at 10:45 AM
Topic: loss of bass
Posted By: SPS70129
Subject: loss of bass
Date Posted: May 14, 2004 at 12:42 PM
ok, this is what i have: 2 punch 12's, kenwood 600 watt amp, and kenwood mp919 (awsome radio). it sounds great at medium volume, but as i get to the louder volume the bass tends to fade a little ( i don't mean that im maxing the radio out, but for instance it hits at 20, but if igo to 25 the bass seems to fade alittle. now the radio goes to 40 i think (never been there). does anyone have a suggestion?
thanks
Posted By: sam1
Date Posted: May 14, 2004 at 12:55 PM
what are your gains at?  if theyre too high your probably clipping you sub after 20.  take your stereo and turn it to about notch 30 or so, then turn the gain all the way down on the amp.  then slowly turn it up until it starts to distort.  turn it back down like a 1/8 of a turn and your set.
Posted By: neo
Date Posted: May 14, 2004 at 3:55 PM
sounds like you're definately clipping.  I agree with sam1 on this.  turn all ur gains down and any other bass enhancement devices all down and then turn your head unit up to the maximum clean volume and then turn your gains up from there slowly up till you hear distortion and then back it off just a little
Neo,Solving All The Worlds Problems
Posted By: audiokid1
Date Posted: May 14, 2004 at 8:46 PM
This might sound dumb, but also check to see that the loud feature is off on the deck.
Posted By: auex
Date Posted: May 14, 2004 at 8:47 PM
I agree, it sounds like you are at the limit of your amplifier. Also if loud is on it will distort the base at a lower volume, I hate the stupid loud button. Like they said above set your gains on your amplifier so they match the the radio's highest safe volume setting. On my Kenwood, the radio starts to distort after setting 29, so I have my amplifier's gain set to play the loudest ( safest without clipping) at this level.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
