which amp should i get?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=3221
Printed Date: April 23, 2026 at 4:33 PM
Topic: which amp should i get?
Posted By: decandia748998
Subject: which amp should i get?
Date Posted: August 31, 2002 at 3:00 PM
i have 2 12 inch thunder 8000's. and i dont know which amp would sound best.
any input or advice would help, thanx
Posted By: bberman1
Date Posted: August 31, 2002 at 8:20 PM
What’s your budget?
Posted By: Velocity Motors
Date Posted: August 31, 2002 at 9:28 PM
If they are the MTX T8124A DVC then get the MTX 6500D amplifier. It's a Class D amp that puts out 775 watts RMS and you can wire the 8000's in parallel for some serious bass ! I installed this set up into a 1996 Dodge Dakota PU and the customer almost hit the floor when he turned it up for the first time. Obviously I had to tune the system for SQ otherwise he would have had to wear hearing protection all the time after turning the system past 15 posted_image
Posted By: separisi
Date Posted: September 01, 2002 at 10:59 PM
Try a Fosgate BD1000. It's an extremely strong amp for around $700
