Infinity Headunit No sound
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=32297
Printed Date: April 05, 2026 at 7:49 PM
Topic: Infinity Headunit No sound
Posted By: bubba22
Subject: Infinity Headunit No sound
Date Posted: May 17, 2004 at 6:19 PM
I was given a Infinity radio from a friend. I bought a Metra 71-7001 plug for it, hooked it up, entered the code from the Mitsubishi code card she gave me with the radio. BUT no sound! I check everything and the headunit will go to AM/FM stations and even play a tape, but no sound. One person told me that I need the amp that goes with it. HUH? The metra plug does direct hook up? What have I done wrong??? I am having a hard believing I need an amp, because then why would anyone need a anti-theft code for if it's useless without its amp??? It has a 14pin socket for power/spkrs, a 6 pin din socket for amp?? and CD change socket 16 pin????. Someone please help. For the record the headunit is not hot at all, she just replaced it with a alpine CD unit and she does not like stuff lying around.
Posted By: stevdart
Date Posted: May 17, 2004 at 7:02 PM
Does your car have speakers? What car is it?
------------- Build the box so that it performs well in the worst case scenario and, in return, it will reward you at all times.
Posted By: bubba22
Date Posted: May 17, 2004 at 8:26 PM
But of course ,sir. That is how I knew that the radio was not putting out any sound. I also went and grabed a spkr from my surround sound system to make sure that it just wasn't the car spkrs. I also double checked every connection and any other basic stuff, so I would not waste all of you fine gentlemens time and knowledge when it could have been something easy to fix. That, I feel, would be stupid of myself......
Posted By: customsuburb
Date Posted: May 17, 2004 at 8:49 PM
Some of the infinity systems have external amplifiers on the back of the speaker itself. This might have been the case with the car or truck you took the head-unit from.
Posted By: stevdart
Date Posted: May 17, 2004 at 8:51 PM
The 71-7001 harness plugs into the OEM radio. You must need a harness that will adapt your new radio to your car. ------------- Build the box so that it performs well in the worst case scenario and, in return, it will reward you at all times.
Posted By: Alpine Guy
Date Posted: May 17, 2004 at 9:38 PM
The infinity systems have separate amps on each speaker, i bet if you cranked the deck to full, and put your ear up to a speaker, you may hear it very faintly. It should be a low level signal, just like rca cables. ------------- 2003 Chevy Avalanche,Eclipse CD7000,Morel Elate 5,Adire Extremis,Alpine PDX-4.150, 15" TC-3000, 2 Alpine PDX-1.1000, 470Amp HO Alt.
Posted By: kgerry
Date Posted: May 18, 2004 at 12:18 PM
actually the infinity radios produce normal output, they change the EQing of the music floor, but you should be able to power it up and use it... i would suspect that one of the plugs on the back ( quite likely the 6 pin DIN ) was actually used for a processor or EQ unit and that when unused should have a shorting plug in it...this bridges the audio out / audio in pins.....
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
