door resonance advice
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=32306
Printed Date: April 05, 2026 at 10:31 AM
Topic: door resonance advice
Posted By: kfr01
Subject: door resonance advice
Date Posted: May 17, 2004 at 9:15 PM
Ok.. I got my mbq pce 216's installed in the doors mounted to some custom 3/4" mdf brackets I made.  These brackets were sealed off w/ silicon caulk.  The speaker was mounted to a foam gasket cut w/ the back cut out.  Behind the speaker a deflex pad was adhered to the door metal.
So, they sound great .. but when I get some high bass that both the sub and the speaker play (right around the sub/mid crossover point - 80hz) the plastic door controls (window controls, door locks, etc.) sometimes make an audible vibration.  It makes me angry.  What can I do to stop this?
Thanks,
kfr01
Posted By: customsuburb
Date Posted: May 17, 2004 at 9:38 PM
You could try playing a test tone and finding the exact spot then apply some dynamat, brownd bread, fat mat etc.. to the spot.
Posted By: DYohn
Clear RTV sometimes works to dampening vibrations like that.  Sounds like you did a great job on the insatll!
Posted By: kfr01
Date Posted: May 18, 2004 at 1:18 AM
Thanks DYohn!  I'll try that for the controls and let you know how it works :-)
Posted By: forbidden
Date Posted: May 18, 2004 at 1:32 PM
use some spray adhesive and apply some carpet underlay to the back of the door panel as well. Wrap some around the wiring in the doors where it could rattle against the door panel. Works great as long as the vapour barrier is still on the door skin.
Posted By: stevdart
Date Posted: May 18, 2004 at 5:09 PM
If Dynamat is covering the door skin, and the original moisture barrier has been ripped off and tossed, then does the Dynamat act as a moisture barrier?  Or do I have to cover that with poly film?
