Factory Security System Civic 04
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=32328
Printed Date: April 04, 2026 at 10:21 AM
Topic: Factory Security System Civic 04
Posted By: Daman22257
Subject: Factory Security System Civic 04
Date Posted: May 18, 2004 at 9:12 AM
Ok I"m about to put a system in to my 2004 honda civic.As far as putting in a new head unit.
I'm hoping it's a typical install,but what about the factory alarm system with the keyless entry.
What do I do about that is there a way I can keep it.Or not and if so can some one give me an
idea to what I have to do to integrate it into my new system.
Posted By: jfk51502003
Date Posted: May 18, 2004 at 2:31 PM
YOUR ASKING IF YOU CHANGE YOU H.U....YOU WILL LOSE YOUR FACTORY SECURITY...NOT SURE WHAT YOUR ASKING...???????
Date Posted: May 18, 2004 at 2:55 PM
My 04 Civic has keyless entry built into the radio.And it's got the little factory security system all built into the factory head unit
is there away I can keep that when I replace the factory head unit.
Posted By: kgerry
Date Posted: May 18, 2004 at 3:08 PM
THEY MAKE t HARNESSES FOR NEWER cIVICS THAT ALLOW YOU TO KEEP THE RADIO IN CIRCUIT AND HOOK UP ANOTHER, JUST LIKE gm'S t HARNESS'S FOR cLASS II DATA
Crap, sorry about the caps
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
