Installing in dash-receiver ’99 taurus
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=32943
Printed Date: April 10, 2026 at 3:49 PM
Topic: Installing in dash-receiver ’99 taurus
Posted By: blazemr.marley
Subject: Installing in dash-receiver ’99 taurus
Date Posted: May 29, 2004 at 2:42 PM
yea instead of replacing the whole unit in my 99' taurus im just splicing the wires into the new receiver and i was wondering if any1 has any tips or knows any info on what wires to connect or what to do? i found the ground,power so it turned on..but i need more info on the wires....please help!
Posted By: stevdart
Date Posted: May 29, 2004 at 5:37 PM
Metra should have a harness for this car.  The tuner is at the antenna sidewall in the trunk.
Posted By: auex
Date Posted: May 29, 2004 at 5:54 PM
Uh, yeah. Buy the harness or waste alot of time and effort rewiring the car and antenna. Everything you need is in the trunk. You need this, and if you want the radio in the stock location, and this..
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: May 31, 2004 at 9:56 AM
i need a diagram that will help direct me in the  color code for the stock wires to the deck of a 99' taurus..anything will help....thankz ahead of time.
Posted By: thepencil
Date Posted: May 31, 2004 at 10:05 AM
Colour Code
Be careful whose advice you buy, but be patient with those who supply it.posted_image
Date Posted: May 31, 2004 at 12:10 PM
i just pulled out the stock radio again and those colors do not match.i have a 99'taurus with the digital climate control.
Posted By: auex
Date Posted: May 31, 2004 at 12:36 PM
That is because you have an amplifier in the trunk. Your antenna is also in the trunk. You should buy the wiring harness for this car if you are putting in a radio.
