2000 Ford Focus SE 4 Gauge Power
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=33042
Printed Date: April 08, 2026 at 12:15 AM
Topic: 2000 Ford Focus SE 4 Gauge Power
Posted By: dogmaiwli
Subject: 2000 Ford Focus SE 4 Gauge Power
Date Posted: May 31, 2004 at 2:44 PM
Trying to find a place in the firewall to run it through to the back of the car without drilling holes, can't find anything, Can anyone reccomend a location, or will I have to go under outside, and drill back in or just drill through the fire wall to begin with?
Any recommendations are Greatly Appreciated, Diagrams are even better :)
Posted By: stevdart
Date Posted: May 31, 2004 at 8:43 PM
Don't go outside of the car.  Keep it thru the firewall.  Disconnect battery neg. terminal while you're probing at the firewall.  Use something like a coat hanger, wrap the end well with electrical tape so it doesn't cut into anything.  You may want to raise the front end up on jackstands and look at the firewall from the bottom engine side to get an idea of where to go through.  If you find any bare places, locate the area from the passenger side and pull carpet/pad out of the way to drill.  First hole needs only be big enough for the probe.  If you see the hanger emerge on the other side, redrill to specific grommet size, wrap power wire onto probe, and push through.  Place grommet over the wire and leave it loose, then secure into hole after complete install of wire.
Posted By: stingercaraudio
Date Posted: May 31, 2004 at 10:16 PM
drivers side, about 10 inches above brake pedal. isn't there a spot there?? I thought there was.. if not then do what stevdart said.
Posted By: mobile1
Date Posted: June 01, 2004 at 12:08 AM
Its it a manual or auto. transmission?? if its auto you should be able to drill through the firewall where the clutch normally goes.
