under seat amp install
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=33152
Printed Date: April 05, 2026 at 1:33 PM
Topic: under seat amp install
Posted By: cd2478
Subject: under seat amp install
Date Posted: June 02, 2004 at 7:39 AM
hello again, ive been running all the wires for both of my amps which will be located underneath the seats and be fan cooled, its all been done except the amps being mounted, has anyone done such an install where the amps are mounted to the floor underneath the seats, what exactly would be the best way to mount it and what materials would be good, i was going to mount on some kind of wood to stop it from being so close to what its earthed too ;) keep in mind im doing this from a security point of view, so the harder to steal the more practical it is going to be for myself. any help would be appreciated..thanks
Posted By: RAUL PUENTE
Date Posted: June 02, 2004 at 8:29 AM
what kind of car is this going in. also the wood idea is also a good idea just try to put the wood under the carpet then maybe use some different type of screws or bolts and best thing for security is don't tell anybody where there at.
Posted By: cd2478
Date Posted: June 02, 2004 at 9:06 AM
its going into a 1990 mitsubishi lancer/mirage i was also thinkin of running metal rails across where the bolts are at and joining it onto the seat shafts so the whole seat has to come off to even get access to the rails main thing i forgot to mention..the ground is not flat :s it could be mounted but how would i mount it securely since its on an angle
Posted By: customsuburb
Date Posted: June 02, 2004 at 10:20 AM
To make the ground level for the amp, you could put shims under the carpet where the amp mounts, until its level.
Date Posted: June 02, 2004 at 11:14 AM
hey all you got to do is put your mind to it and do it just take your time it sounds like your on the right track just remember don't tell anybody.
Posted By: One_Evil_Necro
Date Posted: June 02, 2004 at 12:01 PM
Polyurethane spacers work great for me, you can find them at almost any body shop, you can cut them to size, and they work well. ~Jay
Posted By: nickch
Date Posted: June 02, 2004 at 4:50 PM
i'm thinking of doing that as well, as its very hard to dismantle the amp when its under the seat and it seems that the amp is usually the most expensive component in the system. However, i have a feeling that the flooring under my passanger seat has a hump or a metal bump sought of thing and might make mounting my amp a wee bit difficult. can someone post a picture of the polyurethane spacers because i dont think i can visualize how they look like yet.
Posted By: cd2478
Date Posted: June 03, 2004 at 8:53 AM
yeah as nickch said..sounds exactly like what the doctor ordered, but i have no idea what they are
Posted By: nickch
Date Posted: June 03, 2004 at 3:16 PM
i was thinking tho, over here in NZ, there've been some ppl giving the Lightning Audio Bolt Series 450W amp good reviews for powering a single sub system. This one guy apparently says that it made his 12" Pioneer 800W/400Wrms sub go hard. So i was thinking of getting 2 separate amps for both the speakers and the woofer. and since these amps are rather thin. i was just thinking it might be possible to either mount them right next to the "bump", or if the bump is wide enough, right on the "bump" (tho i think there might be a possibility of pressure lines or wires running under the "bump") both on the driver's and passanger's seat.
Posted By: westend
Date Posted: June 03, 2004 at 5:51 PM
Here are some poly urethane bumpers: https://https://www.polyprod.com/diestorage.html. You could just run some screws through the mounting board and let them stick out 1/4" into the carpet. Use some pieces of wood to level the board.
Posted By: cd2478
Date Posted: June 06, 2004 at 2:47 AM
i havent been able to get that website to work for the past 2 days, any other links?
Posted By: nickch
Date Posted: June 06, 2004 at 7:11 AM
https://www.polyprod.com/diestorage.html. he linked it wrong. it should be the above
