how do you wire six subs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=33437
Printed Date: April 05, 2026 at 2:19 PM
Topic: how do you wire six subs
Posted By: skylark
Subject: how do you wire six subs
Date Posted: June 06, 2004 at 11:22 PM
here the problem the p&s calculator does not put dvc into the equation so what would my ohm level be when i wire 6 subs down? also the woofer wire site on rockford fosgate only goes up to four subs. now the subs are kicker solo baric l7 from last year 4 ohm dvc 12's. now i have the power and a hookup on an enclosure and im only gonna use one amp the earthquake 6000 watt d3 amp..............anybody know what the ohm level will be and how should i wire them?
------------- goingcrazyonsound
Posted By: auex
Date Posted: June 06, 2004 at 11:33 PM
Ok, break it down. Six dvc subs can be the same, wiring wise, as 12 svc subs. So you can do it this way(break it down to 2 groups of 6 subs) or you can use either 2ohm or 8 ohm for the subs and play with it that way, you don't want to mess with oddball resistances like half are 8 and half are 2 because some will see more power then others.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: skylark
Date Posted: June 06, 2004 at 11:53 PM
so i wire the subs up to 8 ohmns then wire all down and i end up with 1.3 ohmns? right
Posted By: skylark
Date Posted: June 06, 2004 at 11:56 PM
i still would like to see an chart or something to help me out because im good with visal instructions for some reason i see something be done and i can almost do the exact thing with or without experince.
Posted By: Ketel22
Date Posted: June 07, 2004 at 4:35 AM
have a field day bud. 6 DVC drivers with Voice Coils in Series / Parallel Connecting the two voice coils of each driver in series (+ to -) and the drivers themselves in parallel (+ to +, etc.) will result in the following impedances: Dual-6 Ohm Subwoofers: 2 Ohms Dual-4 Ohm Subwoofers: 1.3 Ohms Dual-2 Ohm Subwoofers: 0.7 Ohms | | | |
------------- Quad L Handyman services
Posted By: Ketel22
Date Posted: June 07, 2004 at 4:36 AM
sorry about the weird way that posted..... ------------- Quad L Handyman services
