Hi level converter
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=33469
Printed Date: April 03, 2026 at 8:43 PM
Topic: Hi level converter
Posted By: davedyer79
Subject: Hi level converter
Date Posted: June 07, 2004 at 2:30 PM
Have a stinger hi level converter to a Memphis 500D connected to a Memphis PR12SVC.  There is a lot of noise out of the speaker, and it pops when I turn my car off.  Today, it just started to rumble real low, and when I stopped to see what's up, I could smell smoke from inside the box.  Whats going on.  I didn't ground the stinger hi level, could that be the problem?  Is this a decent convertor?  It in a 2001 Jeep GC with factory deck.  Thanks.
davedyer79
Posted By: Ravendarat
Date Posted: June 07, 2004 at 2:57 PM
which stinger high level converter, are there just speaker wires commming outta the box or are there terminals on the converter
Posted By: DYohn
Date Posted: June 07, 2004 at 3:21 PM
Also it could be an amplifier clipping issue.  How'd you set the input gain?
Posted By: stevdart
Date Posted: June 07, 2004 at 5:40 PM
Agreed.  It's not the converter.  It doesn't need to be grounded...the ground wires are there for the occasional original systems that are common grounded.  In fact, you wouldn't get any sound at all, if you had a common ground system, and the converter was not grounded.  Twist-tie the ground wires up and go to B:  Dyohn's suggestion on amp clipping.
Posted By: wvsquirrel
Date Posted: June 08, 2004 at 2:32 AM
I hope you ran the Hi Level converter because you had no other choice. They are not the best for SQ and can cause some interference or distortion in the signal. I take it you are still running the factory headunit?
Dyohn's suggestion is a great place to check, I strongly recommend you check your gain setting.
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
Date Posted: June 08, 2004 at 3:04 PM
No, there are just the input speakers wires and the RCA outputs.  What should I have the gain on the amplifier set on?  I know that it is not cranked all the way up.
davedyer79
Posted By: customsuburb
Date Posted: June 08, 2004 at 3:13 PM
1. Turn down the gain on your sub amp all the way, 2. Put in a cd that you like that has good bass in it (like a kick drum), 3. Turn your head-unit's volume control up about 2/3 of the way, or as high as you will ever turn it up, 4. Turn the gain on your sub amp up slowly until you hear distortion coming from your sub(s) (distortion sounds like a popping or rattling coming from the sub, or mushy bass notes), 5. Turn down the gain just below the point of distortion. BTW don't crank up the bass boost either.  If you use it at all, use it moderately, and watch out for distortion (sometimes you can hear it from the drivers seat that well so be careful when you have the volume cranked).
Date Posted: June 08, 2004 at 8:00 PM
The reason why I asked about the converter is because the one with terminals also has adjustable level controls and I have found that if those are turned to high it will cause the signal itself to clip much sooner, hence the reason I asked.
Date Posted: June 09, 2004 at 9:16 AM
Okay, I will try adjusting the gain Friday, but I am getting married this weekend so it is kinda busy.  Would the gain make the speaker smell like that and smoke.  I didn't even have the volume turned up when it did it.  I have the Memphis 16-XO3 3 Way Electronic Crossover coming in a couple weeks so I just needed to get this fixed if it was the converter itself.  I will be using the converter for the input to the crossover.  Thanks to all for the help, and I will let you know how it turns out when I get back from my honeymoon.
David
davedyer79
Posted By: stevdart
Date Posted: June 09, 2004 at 9:21 AM
Congratulations, and have a safe honeymoon.
