'98 tahoe, rattle in barn doors
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=33524
Printed Date: April 05, 2026 at 9:27 PM
Topic: '98 tahoe, rattle in barn doors
Posted By: axonal
Subject: '98 tahoe, rattle in barn doors
Date Posted: June 08, 2004 at 3:11 PM
Anyone have any suggestions to remove the rattle in the barn doors of a '98 tahoe? It seems to be an issue of the doors being a little loose when closed but I cant figure out any way to tighten the doors to each other to prevent them rattling against each other.
Posted By: chasesaccessori
Date Posted: June 08, 2004 at 5:17 PM
Add or replace the weather striping on the doors.
(owner/installer)
Chase's Accessories
Ridgecrest, CA
in business since 92
Posted By: stevdart
Date Posted: June 08, 2004 at 11:21 PM
Presuming, since this is a car audio forum, that you have a subwoofer back there....if the rattling occurs with the sound pressure and frequencies of the subs, do you have dampening material on that sheet metal?
Posted By: axonal
Date Posted: June 09, 2004 at 1:52 AM
The rattling is do to the fact that two doors rattle against each other, and not cause of the metal of the doors itself. The weather stripping might be the solution, but I dont seem it will solve the problem. Basically, the problem goes away when I push against the doors so they don't have room to move in and out. If you've seen the barn doors on suburbans/tahoes, you'll know that one door latches into the other to lock. I just need to find a way to get the doors to close a bit tighter rather than having that little bit of give from the door hinging on the other.
Posted By: Ketel22
Date Posted: June 09, 2004 at 3:21 AM
you can move the actual locking mechanism, the latch and the "pin" (the name is illuding me due to intoxication) just move them farther apart and the doors will be pulled closer together when lock, but will require move effort to actually latch.
Quad L Handyman services
