sub wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=33938
Printed Date: April 19, 2026 at 3:30 AM
Topic: sub wiring
Posted By: AJRXtreme
Subject: sub wiring
Date Posted: June 15, 2004 at 4:10 PM
I just got my subs and box today but the subs didnt come installed into the box enclosure. They didnt come with any wires and i wanted to know what wiring i needed to hook the subs into the box.
03 F150 on 24's
HU:Pioneer DVD5700
Frt:MC57
Subs:(12)S12L7
Amps:(3)KX2500.1's, MC-2004
Posted By: kgerry
Date Posted: June 15, 2004 at 4:23 PM
some 12 gauge speaker wire is all you should need
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: DYohn
Date Posted: June 15, 2004 at 4:30 PM
Actually you can do with 16 gage for almost all installations.
Date Posted: June 15, 2004 at 4:35 PM
let me show you picture of the back of the sub and then the inside of the box and tell me exactly what i need to do to hook it up
03 F150 on 24's
HU:Pioneer DVD5700
Frt:MC57
Subs:(12)S12L7
Date Posted: June 15, 2004 at 5:43 PM
how do i hook the wiring from the sub to the side of the box enclosure?
03 F150 on 24's
HU:Pioneer DVD5700
Frt:MC57
Subs:(12)S12L7
Posted By: kgerry
Date Posted: June 15, 2004 at 5:50 PM
solder them on both sides, at the driver and at the terminal connector... DYohn is right 16 gauge will probably suffice...i make it a personal rule to use 12 gauge  for all my sub applications and 16 gauge for my satellites....  but 16 gauge  will probably be fine
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
Posted By: stevdart
Date Posted: June 15, 2004 at 6:10 PM
kgerry can probably solder to the speaker with no problems, but I wouldn't recommend you try that.  The glue on the speaker could get soft.  Crimp a female disconnect onto the speaker wire, then push it onto the speaker terminal.  You can do the same at the box terminal.  If you have a good crimper, you'll get a good connection.  If you are trying to make do with pliers, I suggest you run out and get a crimper.  See this for pictures.
Posted By: Ketel22
Date Posted: June 15, 2004 at 6:12 PM
with all of those suggestions it great, but he may have push connectors or screw connectors on his subs. i would solder to the terminal in the box.
Quad L Handyman services
