HU clipping
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=34259
Printed Date: April 18, 2026 at 3:34 AM
Topic: HU clipping
Posted By: xTimx
Subject: HU clipping
Date Posted: June 20, 2004 at 7:43 PM
is there a way of finding out a HU's clipping or sensitivity from using a multimeter? but this has nothing to do with the amps. just the HU. my HU is a jvc 1150.
xTimx
Posted By: shaman
Date Posted: June 21, 2004 at 1:16 AM
Well no, you would need to see the wave form to tell if it was clipping.  You could look at the rated output (for RCA's I take it) and see if you are exceeding that with a good mulitmetter (one that will give you RMS) and some test tones.  That would not really tell tou if there is a clipping condition or not.
Posted By: shaman
Well no, you would need to see the wave form to tell if it was clipping.  You could look at the rated output (for RCA's I take it) and see if you are exceeding that with a good mulitmetter (one that will give you RMS) and some test tones.  That would not really tell you if there is a clipping condition or not.
Posted By: kgerry
Date Posted: June 21, 2004 at 10:17 AM
the ideal way would be with a scope or scopemeter....but as far as just looking at a voltage, no not reliably or accurately
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: DYohn
Date Posted: June 21, 2004 at 10:33 AM
Actually I would have to say no, you can't tell if an amp is clipping simply using a multimeter.  You can assume it is if the output voltage stops increasing as the volume is turned up, but you really cannot tell.
An easy way to find the clipping point is to listen for it.  Here's one technique.  Get a test tone CD with a 1000Hz (1KHz) tone recorded at 0db.  (Turn your amplifier gain all the way down if yu are using external amps.)  Wear hearing protection.  Play the 1KHz test tone and slowly increase the volume on your head until you can hear the tone change.  It will go from being "clear" to being "shrill."  This is the head unit clipping point and you should never, ever turn the head up past this point.  It is also the maximum output for setting amplifier gain.
