Infinity Amps, any good?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=34263
Printed Date: April 18, 2026 at 2:17 PM
Topic: Infinity Amps, any good?
Posted By: gjones77
Subject: Infinity Amps, any good?
Date Posted: June 20, 2004 at 8:59 PM
Just curious, I'm looking at the new Infinity Reference 4 channel and Mono block. Give me your opinions, I'd greatly appreciate it
Posted By: Ravendarat
Date Posted: June 21, 2004 at 2:48 AM
I have the mono Block on my display board right now and I think its sounds nice but has no balls for the money
Posted By: gjones77
Date Posted: June 21, 2004 at 6:53 PM
Thanks for the input, but I was hoping someone who has heard one in a car might have some input. I greatly appreciate what you have to say, but an amp on a wall has too many point of failure that can distort that sounds, since they're often wire into devices that allow you to switch amps and speakers to allow for different combinations.
I have hear from other owners that they liked them quite a bit. I figure anything made by the same company that makes Harmon Kardon and JBL can't be all that bad, plus they're pretty hot looking posted_image
Date Posted: June 22, 2004 at 5:29 PM
You are right that boards can drasticly change the sound of the amps as can the speakers and the enviroment. But it is also reasonable to say that since everyother amp I am comparing it to is under the same limitations then My findings should still be some what credible. I listen to this amp along side the new rockfords and MTX amps and in both cases i found that the amps in both brands out preformed the infinity amps. Of course I was comparing amps in the same price range. The Rockford was less and the MTX was more but they both out preformed the Infinity. You are right that they look hot but the preformance just doesnt justify the tag.
