2004 GMC truck stereo wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=34319
Printed Date: April 18, 2026 at 1:19 PM
Topic: 2004 GMC truck stereo wiring
Posted By: popeye004
Subject: 2004 GMC truck stereo wiring
Date Posted: June 21, 2004 at 8:42 PM
I was just to about install a stereo in a 2004 GMC pickup and I couldn't find the switched ACC wire. I found the ground, 12 volt positive and all the other wires but no ACC wire. Can anyone tell what I might of missed.
The higher the years go the harder its starting to get to install stuff!!!
Posted By: Javelin3o4
Date Posted: June 21, 2004 at 9:43 PM
if your running new wires the orange wire in the ignition harness under the dash should be access.
Date Posted: June 21, 2004 at 10:23 PM
ok and if I want it from the fuse panel which one do I pick acc1 or acc3 I dont think there was a acc2.
Posted By: kgerry
Date Posted: June 22, 2004 at 9:41 AM
the radios dont use a switched acc voltage on the new vehicles.... it utilizes a floating clock circuit
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: foltzy
Date Posted: June 22, 2004 at 11:11 AM
from what i was told, you can tag it into the windshield wiper fuse, but that's just ghetto. Tag it off the Accessory wire in the ignition harness..(It should be a 10-12 guage Orange whire leading from the ignition)
Date Posted: June 22, 2004 at 9:28 PM
Hey guys I got the wire from the heater controls it was a yellow wire is this ok will this work good? it is working fine so far just don't want any sensors to get triped.
