sub and amp impedance matching
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=34331
Printed Date: April 18, 2026 at 6:41 PM
Topic: sub and amp impedance matching
Posted By: markcars
Subject: sub and amp impedance matching
Date Posted: June 21, 2004 at 11:07 PM
if my amp can output either at 2 ohms or 4 ohms and my sub is 3 ohms, how do I get this to work? will the amp work ok or have problems such as getting hot etc? Or should I attach a 1 ohm resistance in series with the sub to make it 4 ohms? Not sure as to what is the best/most efficient way to do this. thanks.
Posted By: DYohn
Date Posted: June 22, 2004 at 8:30 AM
Your amp can handle any load DOWN TO 2-ohms.  3-ohms is fine.  Adding a resister is never, repeat never, a good idea.
Posted By: thepencil
Date Posted: June 22, 2004 at 8:45 AM
This all depends on the type of amplifier that you have. On most 2 channel amplifier you can bridge them at 4 ohm combining the left and right channel to give you the maximum output. On a mono block amplifier the most efficient output is usually at 2 ohm and some even at 1ohm.   To answer your post, the best and safest way to run your 3 ohm sub is to run it at the output of your amplifier where you said 2 ohm. If you run your sub at the 4 ohm output of your amplifier it will be less stable and can over heat overtime and be damage.
The best rule of thumb is stay within the amplifier specification, which the engineer had designed it for.
Be careful whose advice you buy, but be patient with those who supply it.posted_image
Posted By: markcars
Date Posted: June 22, 2004 at 8:55 AM
Thanks. I thought its a bad idea but just had a (bad) thought. Now that I hear it is ok, I'll just use it without fear of burning out anything.
Posted By: markcars
Date Posted: June 22, 2004 at 8:57 AM
My amp says that it can run stable at 2 ohm and 4 ohm. It also says that it can give an output of 250watts at 4ohm load and 500 watts at 2 ohms. So like you said, I will stay withing the specifications. Thanks.
