Power antenna on ’93 4Runner
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=34541
Printed Date: March 20, 2026 at 7:17 PM
Topic: Power antenna on ’93 4Runner
Posted By: zhar
Subject: Power antenna on ’93 4Runner
Date Posted: June 25, 2004 at 3:03 AM
Does anybody know which wire is for the Power antenna for a 1993 4Runner? The ome on the Vehicle info section shows the location but not the wire/connection.
Also, I connected the speakers according to the Vehicle info section but now my rear speakers are out. Here's what it says on the Vehicle Info:
1994 Toyota 4-Runner Stereo Information
Constant 12V+Blue / YELLOW
Switched 12V+Gray
GroundBrown
IlluminationGreen
Dimmern/a
AntennaRight Front
Front Speakers4" Dash
Left Front (+)Pink
Left Front (-)Purple
Right Front (+)Light Green
Right Front (-)Blue
Rear Speakers5 1/4" Side Panels
Left Rear (+)Black
Left Rear (-)Yellow
Right Rear (+)Red
Right Rear (-)White
Any help would be appreciated. Thanks
Posted By: nollaz
Date Posted: June 25, 2004 at 3:41 AM
take the list you just gave us and go to your car and pick out all the wires untill your have a color it dosent list, if theres more than one then grab your test light or volt meter and check each untill you find the remote wire.
yup
Posted By: jimmeezgolfvr6
Date Posted: June 25, 2004 at 5:48 AM
look for pink/blue or BLACK/ red or maybe both. been a while since i've done one of those cars, but i think that's fairly close to being the right colours.
good luck!
Posted By: forbidden
Date Posted: June 25, 2004 at 2:14 PM
The rear speakers may have a factory amplifier, thus you will have to give the factory amp a remote on to trigger it. Some Toyota vehicles used two wires for the antenna trigger. If you still have the factory head unit, reinstall it and check all the lines with a meter.
Posted By: itmdtr
Date Posted: June 26, 2004 at 5:53 AM
I have the wiring diagram, but it's in PDF format Acrobat Reader, so I can't upload it.
I need your e-mail, and I'll send it to you.
itmdtr
Posted By: zhar
Date Posted: June 27, 2004 at 4:18 AM
zarjov@aol.com
Thank you for all your help
Posted By: itmdtr
Date Posted: June 27, 2004 at 6:14 AM
I sent both, the power antenna and radio wiring.
itmdtr
