Adding Relay to Remote
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=3493
Printed Date: April 24, 2026 at 4:10 AM
Topic: Adding Relay to Remote
Posted By: ih8u37
Subject: Adding Relay to Remote
Date Posted: September 10, 2002 at 9:13 AM
I often see on here people recommending the use of relays when multiple remote turn-on leads are used. I understand The basic principle of a relay & what they do, but have yet to use one. I have three amps, & all three remotes are spliced together coming from the EQ. Where can I find a good, detailed diagram or instruction page pertaining to how & what type of relay I should use? Thanx in advance.
Posted By: Velocity Motors
Date Posted: September 10, 2002 at 12:01 PM
Positive Input-----> Positive Output Relay Diagram:
  • 87 - Constant
  • 86 : GROUND
  • 30 - Remote Wire Accessories ( amps, EQ's, processors )
  • 85 : Remote Input from HU
  • 87a: NOT USED
